i have about 1 second lag with the SpaceNavigator and it also just can navigate in one direction after the other. This means for example when i move in one direction and rotate at the same time, it starts moving after about one second, when the move is finished it starts to rotate. Its like the navigation is serial processed.
I have this problem in Catia v5 R20. Running the 3DxWare 10.1.0, 3DxWinCore 17.1.0.10275, SpaceNavigator V4.31. Win7 32Bit via VirtualBox on OSX Mavericks.
Running the trainer or the puzzle works perfekt. I reinstalled and rebooted several times without success.
Any ideas?
regards, Andreas
Lag and one time movement with SpaceNavigator in CatiaV5 R20
Re: Lag and one time movement with SpaceNavigator in CatiaV5
i could fix the problem with the serial movement by disabling the windows firewall. But still have one second lag...
