Using the SpaceMouse Pro in a workstation accessed in the distance?
The SpaceMouse Pro always worked perfectly with me when used on my laptop. Now I am working on a workstation through "connection to Remote Desktop" using my laptop as monitor and the SpaceMouse Pro does not work in its entirety (the keys esc, alt, ctrl and shift work but not the cap).
I have already installed the drives in the workstation but did not work. I know that if i connect the SpaceMouse Pro directly to the workstation it works but that’s not possibly im my case because the workstation in several meters away of me.
Is there any solution?
(sorry for my bad english)
SpaceMouse Pro in a workstation accessed in distance
Nuno Barbosa
Re: SpaceMouse Pro in a workstation accessed in distance
Hello Nuno Barbosa,
to be able to use the 3D mouse remotely you need a software that supports the USB forwarding. This would be for example HP RGS, which actively supports our 3D mouse. You can find a list of supported software here.
