I've noticed a odd thing when using my SpaceNav i Ubuntu 7.04, first of all, when ever i shutdown the driver connection via the sdk i get a window in my face saying i should save the current settings for this application, at the beginning i did that and set it to autosave until i noticed that whenever it save the settings it stopped sending events to my window.
Oh and the motif windows are ugly :S cant you guys make a ncurse based interface or just plain commandline instead?
A odd thing with the driver
Hi Absum,
you get the "Save dialog" everytime:
1. The configuration is modified and your application uses "MagellanClose()" or you change focus to another application.
2. Yor your application registers at the driver, no configuration exists and your application uses the "MagellanClose()" function to "unregister" from the driver or you change focus to another application.
Note: "change focus to another application" means, that there either exists a configuration for this application or this application registers at the driver.
Regarding your other issue:
Concerning the "ugly Motif windows".. NCurses?
No, honestly: Our driver is meant to support graphics application. Therefore it doesn't make sense to do a terminal application.
Maybe in a future version we will possibly provide a modern GUI for
the driver.
Regards
Christian
Please uncheck "autosave" and look what the "Save dialog" say the configuration is saved for? Is this the correct window name (your applications window)?... set it to autosave until i noticed that whenever it save the settings it stopped sending events to my window.
the driver.
Regards
Christian
Hi Absum,
this is my first post in this forum and got the same problem too.
For me the trouble comes if i start the 3d connexion driver on another desktop
than blender ( i do this to have a cleaner workspace).
so my workaround is :
start ubuntu , start the driver ,start blender (or the 3d app.) make one move
with the space pilot in your app. than all works fine and you can push the
driver window to another desktop.
