I'm attempting to write a 'C' wrapper to COM...
Zekaric
Post by Zekaric »
I'm trying to get the SpacePilot and SpaceNavigator to work with our product but I'm a little stuck on a 'C' wrapper. Our product has some legacy issues and 'C' is the easiest way to hook things in. The project currently, a little rough, is here...
c wrapper lib
I'll have to admit, I'm not that versed in ATL/COM stuff either and when I compile (VS2005) the above project I get the following errors (There are more than just the one listed but they are the same.)
1>c:\pmin\mtl\libastronaut\libastronaut.cpp(188) : error C3723: '_ISimpleDeviceEvents::DeviceChange': could not resolve event
1>        c:\pmin\mtl\libastronaut\debug\tdxinput.tlh(316) : see declaration of '_ISimpleDeviceEvents::DeviceChange'
1>        The event handler is one of:
1>        c:\pmin\mtl\libastronaut\libastronaut.cpp(69): could be 'HRESULT EventHandler::OnDeviceChange(long)'
1>        There are no events:
1>        c:\pmin\mtl\libastronaut\debug\tdxinput.tlh(316):  'HRESULT _ISimpleDeviceEvents::DeviceChange(long)': is not an event
I'm wondering if anyone knows what the problem is and how I might be able to fix it.
Thanks.
- Robbert de Groot (AKA: Zekaric)
Zekaric
Post by Zekaric »
Sorry for the casual viewer who doesn't want to download the zip. I'm trying to __hook() in an event. (__unhook() also.)
Hi Zekaric,
It may be easier for you to use the old COM-less SDK. It is just C. It can be downloaded in the Archive section after you select your device type.
3Dx Software Development
Zekaric
Post by Zekaric »
jwick wrote:Hi Zekaric,
Ok. My only concern with this route is if 3dconnexion will abandon the 'C' library at a future date and leave us hanging. We've hit something like that before with another vendor. Something we'd not like to have repeated.
But I'll try the COM-less SDK instead. Thanks.
Hi Zekaric,
There are far too many ISVs using the C SDK for us to abandon it.
You can download it from support>driver downloads->pick your device->archive.
Camael
Post by Camael »
I've tried to write my application using the COM api so far and now I have the same output about the event not being resolved as above. Is there any mayor case for this to happen? Are there any specific project settings/defines that have to be taken? Or does it even only work when the project is created with the ATL-wizard?
What I realized is, that the generated tdxinput-interface file for my project doesn't declare the parameters of DeviceChange as [in] (I'm not THAT experienced with this topic, so I don't know if this is important).
Thanks in advance,
Joachim
mbonk
Post by mbonk »
I couldn't download the c wrapper lib: doesn't seem to exist anymore.
Nonetheless have a look at this viewtopic.php?t=1251
I think you may be having issues with the attributes.
Markus
Camael
Post by Camael »
Right, and I also forgot to add the " embedded_idl"-switch in the #import-statement. Works now - thanks.
Regards,
Joachim
