Driver v10.2 is not working in Max 2014 - confirmed on multiple workstations. How can this happen?!
Also 3dxstd.dlu plugin usually found inside the max stdplugs folder is not there. It is also not inside Max 2015 either but Mxx 2015 works.
Latest v10.2 driver not working in Max 2014!
rogerchristmas
Re: Latest v10.2 driver not working in Max 2014!
I am having the same problem.
In fact, I have been having multiple issues with all of the drivers after V3-17-4.
rogerchristmas
If this keeps up, and if I can't get Max 2015 to work as easily as as it does using v3.17 then I will have to sell the Spacemouse pro and look for another option. Until then let's hope they fix the issues I have found with v10.2 while testing it in Max 2015 here viewtopic.php?f=25&t=9588
Can anyone get it working in Max 2014?
Hi all,
have you checked if the solution described here solves you problem?
UtaSH wrote: ...
please remove the existing settings that you have for the driver. See here how to do that.
rogerchristmas
Hi UtaSH,
This fixed the problem for Max 2014.
Please please can you respond to countless suggestions that I have made on this forum that may solve the 'Move tool bug' ie selecting and object in Max and rotating view with Spacemouse pro makes object slide/ jump around - even with latest drivers v10.2 My suggestion to fix it is to follow the behavior of older drivers eg v3.17 that DISCONNECTS itself from the selected object in Max so it can't move object while turning - SIMPLE right???
Please can other users support this suggestion, as it should solve the issue once and for all.
rogerchristmas
UPDATE: In fact even in v3.17 if you try and grab the object in Max after it disconnects from the object upon rotation of view, it slides and jumps around erratically- confirming that the disconnection works!
rogerchristmas
Update: Test this suggestion in OBJECT MODE
ps. please add and edit option to your forums
Hello rogerchristmas,
I have forwarded your input to the development team. I will let you know when I have more information about this.
