Hi to all, since i've switched to win8.1 and autocad 2014 i can't load command bar (3dxpivot,fly,etc) from autocad toolbar menu.
i've checked that .arx is working, Autocad says that 3dxAUTOCAD.arx is correct loaded at startup but it doesn't work and the toolbar is missing.
i've tried a clean install with no results,please help me i desperate need 3dxpivot feature to set the pivot correctly on large model.
Cristian.
Autocad 3dxAUTOCAD.arx
Re: Autocad 3dxAUTOCAD.arx
Hi Cristian,
do you get any error message? Or any information in the command line window?
Have you tried the command
- NAVBARDISPLAY
