AppCommand in 3DxWare Properties
Robbischubser
Post by Robbischubser »
I want to create a command which is sent by SI_APP_EVENT. I understand that I therefore need an entry in the .cfg like this:
<ButtonAction Type="AppCommand">
			<ID>AppCommand_ToggleMode</ID>
			<Name>Toggle operating mode</Name>
			<AppCmdID>ToggleMode</AppCmdID>
</ButtonAction>
This works fine but the 3dxWare-GUI wont show this entry. It is not selectable by the user. If I change 'AppCommand' to 'App' the entry shows up in the GUI, but is obviously not send through SI_APP_EVENT. Any ideas what to do to make this command user-selectable?
Re: AppCommand in 3DxWare Properties
Your xml looks fine.
Try the latest version of the GUI (3DxWare 10.2.1).
Those commands are mixed in with other commands now. They are not in their own section.
Robbischubser
Unfortunately this doesnt work out either.
I have:
1. Installed 3dxWare 10.2.1
2. Created a Application specific XML in C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg (See below)
3. Deleted the 3dconnexion entrys from C:\Users\<user>\AppData\Local and C:\Users\<user>\AppData\Roaming
When the Application is started I can use the 'Standard'-Button to configure V3DK_1 to my AppCommand. But its still impossible to choose the AppCommand from the list of available commands.
My Application specific XML:
(c) Copyright 3Dconnexion. All rights reserved.
$Revision: 10997 $
<AppCfg Default="true" xmlns="" CfgFormatVersion="1.1" ThisFileVersion="1.1">
	<AppInfo>
		<Name>MyApp</Name>
		<VersionRange>
			<Min>1.0</Min>
			<Max>1.0</Max>
		</VersionRange>
		<ExecutableName>*.*</ExecutableName>
		<ApplicationIcon>3Dx.ico</ApplicationIcon>
		<Transport>S80</Transport>
		<SendDeviceChangeEvent>false</SendDeviceChangeEvent>
		<IgnoreMouseWheelInertia>true</IgnoreMouseWheelInertia>
	</AppInfo>
	<CfgProperties>
		<Access>
			<ReadOnly>true</ReadOnly>
			<AllowInheritance>true</AllowInheritance>
			<Hidden>false</Hidden>
			<Ignore>false</Ignore>
		</Access>
		<Grab>None</Grab>
	</CfgProperties>
	<Settings>
		<ResponseCurve>1.7</ResponseCurve>
		<ScaleX>4.00</ScaleX>
		<ScaleY>4.00</ScaleY>
		<ScaleZ>4.00</ScaleZ>
		<ScaleRx>4.00</ScaleRx>
		<ScaleRy>4.00</ScaleRy>
		<ScaleRz>4.00</ScaleRz>
	</Settings>
	<ButtonActions>
		<!-- App Handled Actions -->
		<ButtonAction Type="App">
			<ID>App_ResetYourView</ID>
			<Name>STR_APP_RESETYOURVIEW</Name>
		</ButtonAction>
			<ID>App_ShowYourGUI</ID>
			<Name>STR_APP_SHOWYOURGUI</Name>
		</ButtonAction>
		</ButtonAction>
	</ButtonActions>
	<!-- For each Legacy app, default to showing the 3DxWare Popup menu for the menu key, since it used to show the 3DxWare GUI. -->
	<!-- The Base, sends this key to the app -->
	<Devices>
		<Device>
			<VendorID>0</VendorID>
			<ProductID>0</ProductID>
			<AxisFilter>None</AxisFilter>
			<CurrentButtonBank>Default</CurrentButtonBank>
			<ButtonBank Default="true">
				<ID>Default</ID>
				<Button ReadOnly="true">
					<Input>
						<ActionID>V3DK_MENU</ActionID>
					</Input>
					<Output>
						<ActionID>Driver_ShowDriverGUI</ActionID>
					</Output>
				</Button>
				<Button>
					<Input>
						<ActionID>V3DK_FIT</ActionID>
					</Input>
					<Output>
						<ActionID>App_ResetYourView</ActionID>
					</Output>
				</Button>
				<Button>
					<Input>
						<ActionID>V3DK_1</ActionID>
					</Input>
					<Output>
						<ActionID>AppCommand_ToggleMode</ActionID>
					</Output>
				</Button>
			</ButtonBank>
		</Device>
    </Devices>
	<UI>
		<ButtonMappingEditor>
			<UseApp>false</UseApp>
			<SyncFunctionID>204</SyncFunctionID>
		</ButtonMappingEditor>
		<AdvancedSettingsEditor>
			<SyncFunctionID>205</SyncFunctionID>
		</AdvancedSettingsEditor>
	</UI>
</AppCfg>
Sure enough.
The AppCommands don't appear in the GUI. We have to fix that.
We are looking at it. It is just a GUI issue.
You should be able to use the commands, but you have to edit the Cfg yourself.
Thanks for pointing it out.
Robbischubser
is there a date I may look forward to for a fixed driver?
I think there is a driver release planned for next month.
