3ds max Rotation Center "Use Selected Item" not working correctly
katho3d
Post by katho3d » Sat Aug 08, 2020 11:51 pm
With "Use Selected Item" (Rotation Center) mode enabled, the SpaceMouse doesn´t behave as expected anymore. In 3ds max sub-object mode, it still uses the pivot point as rotation center instead the selected vertices, edges or polygons. This makes it impossible to navigate on bigger objects.
This problem is there since one year now (including 10.6.9), the latest driver working correctly is 3DxWare 10.6.0. So we are unable to use the 2021 version of 3ds max.
Please fix this bug, because this makes it impossible for us to work with your 3D Devices. Thank you.
