Spaceball 5000 serial, Reversing axises
merrin
Post by merrin »
I have got an old spaceball 5000 serial for at my home, but i am used to work with reversed zoom and translation... is there any possibility to do this with the 'newest' driver for this?
thx
M
The current drivers do not support serial devices. The last driver that works with serial devices can be downloaded from the web site.
In that driver, you can switch the directions on the axes only by editing the config file for your application. If you find the AXIS_MAP_HRZ_USER entry in the config file for your application, you can change the direction of the axes by changing the case of the letters. For example, changing XYZRUV to xyzruv will reverse each and every axis.
merrin
Post by merrin »
Where can i find this driver config file?
The default config files for your applications are in (for an english system) C:\Program files\3dconnexion\3dconnexion 3DxSoftware\3DxWare\en_us\profiles\default. Once you make changes, the changes are saved in %appdata%\3dconnexion\3dxware\profiles.
