I have got an old spaceball 5000 serial for at my home, but i am used to work with reversed zoom and translation... is there any possibility to do this with the 'newest' driver for this?
thx
M
Spaceball 5000 serial, Reversing axises
The current drivers do not support serial devices. The last driver that works with serial devices can be downloaded from the web site.
In that driver, you can switch the directions on the axes only by editing the config file for your application. If you find the AXIS_MAP_HRZ_USER entry in the config file for your application, you can change the direction of the axes by changing the case of the letters. For example, changing XYZRUV to xyzruv will reverse each and every axis.
