3DxTrainer.exe COMException
squidy123
Post by squidy123 »
I bought a 3Dconnexion SpaceMouse Enterprise Kit 2. After installing the software I can not start the Trainer - everything else seems to work. A first Test with Fusion 360 seems ok.
I installed all windows updates, restarted, uninstalled 3Dconnexion software and installed them again (a few times), but the Trainer does not start! :cry:
In the Event Viewer I see the following errors:
Application: 3DxTrainer.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Runtime.InteropServices.COMException
   at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(System.Guid ByRef, System.Object, Int32, System.Guid ByRef)
   at System.Windows.Forms.AxHost.CreateWithoutLicense(System.Guid)
   at System.Windows.Forms.AxHost.CreateWithLicense(System.String, System.Guid)
   at System.Windows.Forms.AxHost.CreateInstanceCore(System.Guid)
   at System.Windows.Forms.AxHost.CreateInstance()
   at System.Windows.Forms.AxHost.GetOcxCreate()
   at System.Windows.Forms.AxHost.TransitionUpTo(Int32)
   at System.Windows.Forms.AxHost.CreateHandle()
   at System.Windows.Forms.Control.CreateControl(Boolean)
   at System.Windows.Forms.AxHost.EndInit()
   at _3DDemo.Form1.InitializeComponent()
   at _3DDemo.Form1..ctor(Boolean)
   at _3DDemo.Form1.Main(System.String[])
Faulting application name: 3DxTrainer.exe, version: 3.2.7.0, time stamp: 0x5f062207
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1466, time stamp: 0xc79f51a9
Exception code: 0xe0434352
Fault offset: 0x0012b662
Faulting process ID: 0x1e90
Faulting application start time: 0x01d808b1c3359d78
Faulting application path: C:\Program Files (x86)\3Dconnexion\3DxWare\3DxTrainer\3DxTrainer.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report ID: c1d784a1-98ea-43f5-99a0-cfb0c07726d7
Faulting package full name:
Faulting package-relative application ID:
Any help is appreciated, thanks
squidy123
Re: 3DxTrainer.exe COMException
Post by squidy123 »
After installing the Media Feature Pack with "Apps & features -> optional Features -> Add a feature", the Trainer starts without a problem. It seems that there was a missing dependency (codec or something else) and the application doesn't inform about it when starting - it fails silently (you can see the process for a short time (1-2 secs) in the task manager) with the errors in the event viewer.
But I'm happy that the trainer is now starting! :D
nurquhar
Post by nurquhar »
Support Just Told me to look at this thread, I looked for the 'add media' option mentioned above but it does not exist for my Windows 10 pro. :(
This is the message from support, which makes you wonder why the printed quick start instructions tell you to use it :shock: :
Hallo,
Trainer is no longer supported and developed by us and problems may occur. We plan to remove this program in future versions of our driver,
please see if the procedure described in the Forum helps in your case.
3DxTrainer.exe COMException - 3Dconnexion Forum
Best,
