I installed all windows updates, restarted, uninstalled 3Dconnexion software and installed them again (a few times), but the Trainer does not start!
In the Event Viewer I see the following errors:
Application: 3DxTrainer.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Runtime.InteropServices.COMException
at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(System.Guid ByRef, System.Object, Int32, System.Guid ByRef)
at System.Windows.Forms.AxHost.CreateWithoutLicense(System.Guid)
at System.Windows.Forms.AxHost.CreateWithLicense(System.String, System.Guid)
at System.Windows.Forms.AxHost.CreateInstanceCore(System.Guid)
at System.Windows.Forms.AxHost.CreateInstance()
at System.Windows.Forms.AxHost.GetOcxCreate()
at System.Windows.Forms.AxHost.TransitionUpTo(Int32)
at System.Windows.Forms.AxHost.CreateHandle()
at System.Windows.Forms.Control.CreateControl(Boolean)
at System.Windows.Forms.AxHost.EndInit()
at _3DDemo.Form1.InitializeComponent()
at _3DDemo.Form1..ctor(Boolean)
at _3DDemo.Form1.Main(System.String[])
Faulting application name: 3DxTrainer.exe, version: 3.2.7.0, time stamp: 0x5f062207
Faulting module name: KERNELBASE.dll, version: 10.0.19041.1466, time stamp: 0xc79f51a9
Exception code: 0xe0434352
Fault offset: 0x0012b662
Faulting process ID: 0x1e90
Faulting application start time: 0x01d808b1c3359d78
Faulting application path: C:\Program Files (x86)\3Dconnexion\3DxWare\3DxTrainer\3DxTrainer.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report ID: c1d784a1-98ea-43f5-99a0-cfb0c07726d7
Faulting package full name:
Faulting package-relative application ID:
