Spacemouse driver not working in Ventura
cjadams
Re: Spacemouse driver not working in Ventura
Post by cjadams »
NOT sure this is relevent. i did discover a DEXT file that was a pointer i assume to the original one.. but it errors out and i can't delete the old pointer shortcut file even with sudo..
cjadams
Post by cjadams »
As for the earlier question. yes the 3dc helper is in launch..
see these screen shots though.
Screenshot 2022-07-11 at 1.22.51 PM.png (16.75 KiB) Viewed 50558 times
Screenshot 2022-07-11 at 1.22.34 PM.png (191.28 KiB) Viewed 50558 times
zoomer
Post by zoomer »
Ventura Public Beta too.
For the first time larger problems with PB.
Just because I have Little Snitch Fire Wall which was not yet ready in stable version.
Meant no more network connections and Internet Access - except for mail.
But I found a early build version of LS which finally works.
Not that easy to download or copy over - without internet and networks though :)
OK, so Ventura PB as basically fine as usual.
Nevertheless bringing Little Snitch to work was not that easy and same for 3DConnexion
Driver. Needed lots of reboots and fiddling. It would only show my old Space Navigator
but not my CADMouse.
But as I do not had to install 3DCon Driver from scratch it now works for me.
So I assume my Enterprise would also work.
cjadams
Post by cjadams »
what else dod you need to do? in my case i tried normal install hit the allow 2 times one for each part of the driver and then got blocked at the weird ! dialog
forced quit settings and rebooted...still no luck...so next i uninstalled disabled gatekeeper all together set to allow drivers from "anywhere" which then showed up..tried installing again...same situation didn't seem to make any difference sadly
zoomer
Post by zoomer »
Update,
no, the Driver does not work correctly.
After each restart of Ventura the driver is off or deactivated.
I can reactivate the driver by opening Ventura Settings and go to 3DCon Tab.
But then it will only show my old Space Navigator.
To also reactivate my CADMouse I need to plug it off/on again.
cjadams wrote: ↑Tue Jul 12, 2022 3:19 pm forced quit settings and rebooted...still no luck...
I just sent a private message with detailed instructions in an attempt to get rid of that symlink (which may indeed be blocking the driver installation). We're recommending to try to delete the symlink in "Recovery mode".
zoomer wrote: ↑Wed Jul 13, 2022 1:42 am After each restart of Ventura the driver is off or deactivated.
We don't see this.
After rebooting, is the "3DconnexionHelper" program running? You can check this using Activity Monitor.
If it is not running, can you please check if you can find the following file in your system:
/Library/LaunchAgents/com.3dconnexion.helper.plist
This is the file used to start the driver automatically.
zoomer wrote: To also reactivate my CADMouse I need to plug it off/on again.
Are you perhaps using a dongle or external USB hub?
zoomer
Post by zoomer »
I can confirm that
exists
I will check after next reboot if "3DconnexionHelper" program is running automatically or not.
So far I would have assumed it will not but start when I open Driver tab in System Settings,
as it takes a bit of time and shakes until it shows the Space Navigator.
As said, the CADMouse needs an extra plug out/in to also awake.
(But It works as a Mouse - without extra button assignments - so maybe the driver is already running partly ?)
zoomer wrote: ↑Wed Jul 13, 2022 2:49 am As said, the CADMouse needs an extra plug out/in to also awake.
And are you using a dongle or an external USB hub to connect your CadMouse to the machine?
zoomer
Post by zoomer »
Yes. But for the Space Navigator too.
I only have 2 USBA ports on my M1 Mini.
1 is needed for the Wacom Cintiq, 2. for the Hub.
Basically no chance for a direct USB input.
But I will try the Hub on the Wacom.
zoomer wrote: ↑Wed Jul 13, 2022 4:50 am I only have 2 USBA ports on my M1 Mini.
Two ports should allow you to test using both the SpaceNavigator and the CadMouse to rule out any USB hub shenanigans.
cjadams
Post by cjadams »
ngomes wrote: ↑Wed Jul 13, 2022 2:12 am
Sadly .... was able to ditch that stuck symlink... but uninstall / reinstall later.. still got only one allow not 2 and still showing the error in 3dconnexion home.. and here we are.. same as before.. it just really doesn't like me! - i sent you a followup msg..
Maybe a remote session might be useful.. i'm game if you think it would help.
cjadams wrote: ↑Wed Jul 13, 2022 9:34 am Sadly .... was able to ditch that stuck symlink... but uninstall / reinstall later.. still got only one allow not 2 and still showing the error in 3dconnexion home.. and here we are.. same as before.. it just really doesn't like me! - i sent you a followup msg..
Something appears to be blocking the DriverKit Extension software (dext). If you are not using an MDM tool (like Jamf Pro or similar), then we're running out of ideas to explain why the software refuses to load in your system.
Your case is the only one we are aware and does not appear to be related to macOS 13 ("Ventura").
Just to confirm, would it be possible to share a screenshot of the "Security & Privacy" pane in System Preferences?
The dialogue with only the "Security & Privacy" icon and an "OK" button appears to have been fixed in macOS 13 Beta 3. This is still subject to confirmation.
cjadams
Post by cjadams »
i can confirm that the odd dialog didn't show up this time i installled and i only got one out of the 2 allows... note i even disabled gatekeeper and have the allow set to "anywhere"
