[SpaceMouseCompact] LeftButton Mapping help, pls..
mostly2d
Post by mostly2d »
I have wrote like this;
But, it gave me nothing.
What do I have to do ?
<Button>
		<Input>
		</Input>
	<Output>
			<KeyStroke>
					<Key>4</Key>
			</KeyStroke>
	</Output>
</Button>
Re: [SpaceMouseCompact] LeftButton Mapping help, pls..
You should be able to use the GUI to map a SpaceMouse Compact button to the 'A' key.
mostly2d
Post by mostly2d »
jwick wrote: Sun Dec 18, 2022 11:59 pm You should be able to use the GUI to map ..
Good, Thanks
so, what do you mean by "GUI" ?
Do I have to go to like this ?
mostly2d wrote: Mon Dec 19, 2022 11:45 am so, what do you mean by "GUI" ?
The "GUI" is the "3Dconnexion Settings" program. To open it, search for "3Dconnexion Settings" in the Start menu or double-click on the driver system tray icon. The program can also be opened from the "3Dconnexion Home" panel.
mostly2d
Post by mostly2d »
Fine
My goal is to emit "A" key from my SpaceMouseCompactLeftButton anyway.
So,
I've tired like this;
GUI > Buttons > Left (and, click Drop down of right side of it) > Keyboard > and what ? there is no "A" ??
GUI > Buttons > Left (and, click Drop down of right side of it) > Macros > or something ?
Or and other way ?
Regards
mostly2d
Post by mostly2d »
ah..
I found a way using "Macros".
Is this the best way I could find from SpaceMouseCompact ?
I have double checked it at configuration ".xml" file.
It looks not so "the best way", I guess.
Is there any way like "KB_Tab" key ?
I mean, like a "KB_A" sometihg ?
Regards
mostly2d
Post by mostly2d »
Can I know full list of it ?
A <-- 4
B <-- 5
Do you happen to have a Guide Book or something ?
Regards
mostly2d
Post by mostly2d »
OR
any tiny programs ? simple codes (written in C#) ? to check it out ?
I have skimmed your SDK, unfortunately, for me it looks like an Alien language. though I could handle elementary level of C# projects.
Regards
mostly2d wrote: Mon Dec 19, 2022 2:17 pm Or and other way ?
Go to the "Buttons" panel, click on the button your want to program and simply type the key. This generates a special macro that emulates a single key or keyboard shortcut (say, "Ctrl+A").
mostly2d
Post by mostly2d »
No
I can not find any section from there except Usual Macros.
Like this;
제목 없음.jpg (136.44 KiB) Viewed 3902 times
mostly2d wrote: Tue Dec 20, 2022 4:56 am I can not find any section from there except Usual Macros.
Don't click on the "flyout" arrow.
Just click in the input field of the button (to the left of the arrow) and then press the keyboard key you want to see emulated.
mostly2d
Post by mostly2d »
Wow.
That is tricky.
I will try out.
mostly2d
Post by mostly2d »
Confirmed
That is a... a kind of Macro, any way.
mostly2d
Post by mostly2d »
mostly2d wrote: Mon Dec 19, 2022 2:49 pm Can I know full list of it ?
A <-- 4
B <-- 5
Regards
mostly2d wrote: Mon Dec 19, 2022 2:49 pm Do you happen to have a Guide Book or something ?
We have a user manual (a PDF document). You can open it by going into "3Dconnexion Settings" > More > Manuals.
