mostly2d
Posts: 24 Joined: Sat Dec 17, 2022 12:05 am
Post
by mostly2d » Sat Dec 17, 2022 3:45 pm
I have wrote like this;
But, it gave me nothing.
What do I have to do ?
<Button>
<Input>
<ActionID>HIDButton_1</ActionID>
</Input>
<Output>
<KeyStroke>
<Key>4</Key>
</KeyStroke>
</Output>
</Button>
Posts: 3456 Joined: Wed Dec 20, 2006 2:25 pm
Post
by jwick » Sun Dec 18, 2022 11:59 pm
You should be able to use the GUI to map a SpaceMouse Compact button to the 'A' key.
mostly2d
Post
by mostly2d » Mon Dec 19, 2022 11:45 am
jwick wrote: ↑ Sun Dec 18, 2022 11:59 pm
You should be able to use the GUI to map ..
Good, Thanks
so, what do you mean by "GUI" ?
Do I have to go to like this ?
Posts: 3460 Joined: Mon Nov 27, 2006 7:22 am
Post
by ngomes » Mon Dec 19, 2022 1:09 pm
mostly2d wrote: ↑ Mon Dec 19, 2022 11:45 am
The "GUI" is the "3Dconnexion Settings" program. To open it, search for "3Dconnexion Settings" in the Start menu or double-click on the driver system tray icon. The program can also be opened from the "3Dconnexion Home" panel.
mostly2d
Post
by mostly2d » Mon Dec 19, 2022 2:17 pm
Fine
My goal is to emit "A" key from my SpaceMouseCompactLeftButton anyway.
So,
I've tired like this;
GUI > Buttons > Left (and, click Drop down of right side of it) > Keyboard > and what ? there is no "A" ??
GUI > Buttons > Left (and, click Drop down of right side of it) > Macros > or something ?
Or and other way ?
Regards
mostly2d
Post
by mostly2d » Mon Dec 19, 2022 2:35 pm
ah..
I found a way using "Macros".
Is this the best way I could find from SpaceMouseCompact ?
I have double checked it at configuration ".xml" file.
It looks not so "the best way", I guess.
Is there any way like "KB_Tab" key ?
I mean, like a "KB_A" sometihg ?
Regards
mostly2d
Post
by mostly2d » Mon Dec 19, 2022 2:49 pm
Can I know full list of it ?
A <-- 4
B <-- 5
Do you happen to have a Guide Book or something ?
Regards
mostly2d
Post
by mostly2d » Mon Dec 19, 2022 2:54 pm
OR
any tiny programs ? simple codes (written in C#) ? to check it out ?
I have skimmed your SDK, unfortunately, for me it looks like an Alien language. though I could handle elementary level of C# projects.
Regards
Post
by ngomes » Tue Dec 20, 2022 1:38 am
mostly2d wrote: ↑ Mon Dec 19, 2022 2:17 pm
Or and other way ?
Go to the "Buttons" panel, click on the button your want to program and simply type the key. This generates a special macro that emulates a single key or keyboard shortcut (say, "Ctrl+A").
mostly2d
Post
by mostly2d » Tue Dec 20, 2022 4:56 am
No
I can not find any section from there except Usual Macros.
Like this;
제목 없음.jpg (136.44 KiB) Viewed 3953 times
Post
by ngomes » Tue Dec 20, 2022 5:19 am
mostly2d wrote: ↑ Tue Dec 20, 2022 4:56 am
Don't click on the "flyout" arrow.
Just click in the input field of the button (to the left of the arrow) and then press the keyboard key you want to see emulated.
mostly2d
Post
by mostly2d » Tue Dec 20, 2022 6:28 am
Wow.
That is tricky.
I will try out.
mostly2d
Post
by mostly2d » Tue Dec 20, 2022 6:32 am
Confirmed
That is a... a kind of Macro , any way.
mostly2d
Post
by mostly2d » Tue Dec 20, 2022 6:33 am
mostly2d wrote: ↑ Mon Dec 19, 2022 2:49 pm
A <-- 4
B <-- 5
Regards
Post
by ngomes » Tue Dec 20, 2022 8:12 am
We have a user manual (a PDF document). You can open it by going into "3Dconnexion Settings" > More > Manuals.
