I've got the SpaceNavigator (PE) and own an iMac, running Tiger, and running a virtual machine of XP Pro (VMWare Fusion) in order to be able to run and use Rhino 4.0.
Now, I have installed the drivers for both OSX and XP, in OSX everything is working fine, I can use the device and can simply access and change the settings of the SpaceNavigator. For XP this is a problem, I'm not able to open the Control Panel, I have rebooted the virtual machine; didn't help, removed the driver and installed it again, and again didn't help.
What might be causing this problem, how can this be fixed?
Michel.
3Dconnexion Control Panel can''t open it...
Hi mich.
To check if a device is present, have a look in this Knowledge Base article.
The panel only opens if a device is found. No device, no panel.mich. wrote:Still, I should be able to run/open the Control Panel > '3dxsrv', but this isn't the case.
