Vertical Axis lock in NX
ramsri95
Post by ramsri95 »
Is there a way to lock the vertical axis (like horizon lock in Rhino/Onshape) when using the space mouse in NX? There is a command in NX called 'lock vertical axis' but it only works with a regular mouse, and I can't seem to find the setting for it in the 3Dconnexion application. Thanks!
javierolson
Re: Vertical Axis lock in NX
Post by javierolson »
Hi, it is simple. You can follow these steps.
1. Go to the "Mapping" tab.
2. In the list of available NX commands, find "Lock vertical axis". It may be labeled something like "NX: Lock Vertical Axis".
3. Drag and drop this command onto one of the buttons on your space mouse. Common choices are the top or bottom buttons.
4. Now when you're in NX and using the space mouse, pressing that assigned button will toggle the vertical axis lock on and off, just like using the standard command with a regular mouse.
javierolson
Hope that it will be useful for you.
pizza tower
ramsri95
Post by ramsri95 »
Thanks Javier, but even with the NX: Lock Vertical Axis turned on, I am still flying all over the space when I use the space mouse. I notice that it only locks the vertical axis when I use a mouse. There are separate options for Rhino or Onshape, and I was hoping that 3Dconnexion had a similar patch for NX :(
DavidV
Post by DavidV »
Hello ramsri95,
The driver does give you an option to lock horizon, but vertical axis it does not. your best bet would be to disable the Vertical axis in the Advanced Settings while in NX. There is not a command for it so this means you would need to open the Advanced Settings each time you want to enable or disable the Vertical Axis.
ramsri95
Post by ramsri95 »
Hi David,
How are you able to see a Horizon Lock in the 3Dconnexion App? I've attached images of my NX and Onshape versions of the settings here, and I'm looking for something like the Lock Horizon. Thank you!
DavidV
Post by DavidV »
ramsri95 wrote: ↑Fri Sep 22, 2023 4:04 pm Hi David,
you are looking to Lock Horizon in NX as you do in OnShape Correct?
Easiest way would be to disable an Axis
In NX the option it gives you is Speed. to the left of the Speed bar are boxes which contain check marks in them.
Unchecking a box should disable that Axis and give you the desired effect.
