I have an active Case for this issue with Tech Support and have now requested a follow-up and/or status on that multiple times... and just today got referred to Development since basic troubleshooting has not resolved this issue.
I'm posting here, as well, in the case I can get a response any quicker...
Current setup: Dell Precision 5520 (Client), HP AnyWare (Remote) and BOXX-FLEXX Module (Host)
Problem: Modifier keys on the SpaceMouse Pro do not function whatsoever on the system - I do not get any response with ESC, SHIFT, CTRL or TAB in SolidWorks, Microsoft Products or in File Explorer.
Troubleshooting done so far:
- I've tested other SpaceMouse Pro devices with the same results
- Logged in as a different user (both as a standard user and as an Admin)
- Performed a clean re-install of 3DxWare (as recommended)
- Updated the firmware of the SpaceMouse Pro with 3DxFlash_v2-14-7_r20355
- Reinstalled the ChipSet drivers on the BOXX System
- Restarting the Human Interface Device Service
- Tried inserting "SendInput" as the KMJMechanism in both Global Config files (both in the User Folder and the Program Files (Cfg) Folder
- "Disabled" the "Turn off Windows Key hotkeys" in Global Policy
- Disabled Power control on the KMJ Emulator from the Device Manager
Is there anything else I'm missing on why this continues to be a problem? This issue follows the system, as I've had another Engineer with a fully functional SpaceMouse log into the BOXX System and upon connecting, he loses functionality of these keys, as well.
Any help would be highly appreciated, as this has become a months-long issue.
Thank you,
Matt Hartman
Engineer Technician II
Lost Functionality of Modifier Keys on SpaceMouse Pro
Matt Hartman
Strick Trailers, LLC
Re: Lost Functionality of Modifier Keys on SpaceMouse Pro
<KMJMechanism>SendInput</KMJMechanism> should be the trick.
Please PM your %appdata%\3dconnexion\3Dxware\cfg\global.xml file to me.
By the way, when I customize one of the SpaceMousePro Compact buttons for Shift in Outlook, it does function as expected, and OUTLOOK-KMJ.xml is created in %appdata%\3dconnexion\3Dxware\cfg\, with the following relevant customization:
<Devices>
<Device>
<ID>ID_ProductID_C635</ID>
<ButtonBank Default="true">
<ID>Default</ID>
<Button>
<Input>
</Input>
<Output>
<ActionID>KB_Shift</ActionID>
</Output>
</Button>
</ButtonBank>
</Device>
</Devices>Michael Hoopes
I tried copying the code you sent me @jwick, but I get the same result. I even disconnected the Teradici/HP AnyWare session, unplugged the SpaceMouse, plugged it back in and reconnected the AnyWare Session. Still no functional Keyboard functions.
Any other ideas?
I've tried to map one of his 4 custom buttons to a Keyboard Shortcut in 3DxWare and it does the same thing... No response from the system. If it's mapped to literally anything other command/shortcut, it works fine. It's seemingly ONLY Keyboard shortcuts. It's so odd.
Matt Hartman
mkhartman wrote: ↑Thu Oct 26, 2023 4:36 pmI tried copying the code you sent me @jwick, but I get the same result. I even disconnected the Teradici/HP AnyWare session, unplugged the SpaceMouse, plugged it back in and reconnected the AnyWare Session. Still no functional Keyboard shortcuts...
Any other ideas?
Matt Hartman
Any other ideas?
I've tried to map one of his 4 custom buttons to a Keyboard Shortcut in 3DxWare and it does the same thing... No response from the system. If it's mapped to literally any other command/shortcut, it works perfectly. It's seemingly ONLY Keyboard shortcuts. It's so odd.
Matt Hartman
