Lost Functionality of Modifier Keys on SpaceMouse Pro
mkhartman
Post by mkhartman »
I have an active Case for this issue with Tech Support and have now requested a follow-up and/or status on that multiple times... and just today got referred to Development since basic troubleshooting has not resolved this issue.
I'm posting here, as well, in the case I can get a response any quicker...
Current setup: Dell Precision 5520 (Client), HP AnyWare (Remote) and BOXX-FLEXX Module (Host)
Problem: Modifier keys on the SpaceMouse Pro do not function whatsoever on the system - I do not get any response with ESC, SHIFT, CTRL or TAB in SolidWorks, Microsoft Products or in File Explorer.
Troubleshooting done so far:
- I've tested other SpaceMouse Pro devices with the same results
- Logged in as a different user (both as a standard user and as an Admin)
- Performed a clean re-install of 3DxWare (as recommended)
- Updated the firmware of the SpaceMouse Pro with 3DxFlash_v2-14-7_r20355
- Reinstalled the ChipSet drivers on the BOXX System
- Restarting the Human Interface Device Service
- Tried inserting "SendInput" as the KMJMechanism in both Global Config files (both in the User Folder and the Program Files (Cfg) Folder
- "Disabled" the "Turn off Windows Key hotkeys" in Global Policy
- Disabled Power control on the KMJ Emulator from the Device Manager
Is there anything else I'm missing on why this continues to be a problem? This issue follows the system, as I've had another Engineer with a fully functional SpaceMouse log into the BOXX System and upon connecting, he loses functionality of these keys, as well.
Any help would be highly appreciated, as this has become a months-long issue.
Thank you,
Matt Hartman
Engineer Technician II
Matt Hartman
Strick Trailers, LLC
Re: Lost Functionality of Modifier Keys on SpaceMouse Pro
<KMJMechanism>SendInput</KMJMechanism> should be the trick.
Please PM your %appdata%\3dconnexion\3Dxware\cfg\global.xml file to me.
mhoopes
Post by mhoopes »
By the way, when I customize one of the SpaceMousePro Compact buttons for Shift in Outlook, it does function as expected, and OUTLOOK-KMJ.xml is created in %appdata%\3dconnexion\3Dxware\cfg\, with the following relevant customization:
  <Devices>
    <Device>
      <ID>ID_ProductID_C635</ID>
      <ButtonBank Default="true">
        <ID>Default</ID>
        <Button>
          <Input>
          </Input>
          <Output>
            <ActionID>KB_Shift</ActionID>
          </Output>
        </Button>
      </ButtonBank>
    </Device>
  </Devices>
Michael Hoopes
mkhartman
Post by mkhartman »
jwick wrote: Thu Oct 26, 2023 1:05 pm <KMJMechanism>SendInput</KMJMechanism> should be the trick.
I tried copying the code you sent me @jwick, but I get the same result. I even disconnected the Teradici/HP AnyWare session, unplugged the SpaceMouse, plugged it back in and reconnected the AnyWare Session. Still no functional Keyboard functions.
Any other ideas?
I've tried to map one of his 4 custom buttons to a Keyboard Shortcut in 3DxWare and it does the same thing... No response from the system. If it's mapped to literally anything other command/shortcut, it works fine. It's seemingly ONLY Keyboard shortcuts. It's so odd.
Matt Hartman
mkhartman
Post by mkhartman »
mkhartman wrote: Thu Oct 26, 2023 4:36 pm
I tried copying the code you sent me @jwick, but I get the same result. I even disconnected the Teradici/HP AnyWare session, unplugged the SpaceMouse, plugged it back in and reconnected the AnyWare Session. Still no functional Keyboard shortcuts...
Any other ideas?
Matt Hartman
mkhartman
Post by mkhartman »
Any other ideas?
I've tried to map one of his 4 custom buttons to a Keyboard Shortcut in 3DxWare and it does the same thing... No response from the system. If it's mapped to literally any other command/shortcut, it works perfectly. It's seemingly ONLY Keyboard shortcuts. It's so odd.
Matt Hartman
