Hi everybody:
It seems that there is a problem with the latest version of the 3DxWare driver (10.8.17.3666) and the SME when used in TopSolid 7.17. The view manipulation keys do not work in a TopSolid Assembly document for some reason. They do work in other document types.
Is anyone else experiencing this behavior?
Cheers, Brian
Problem with TopSolid7.17, SpaceMouse Enterprise, and latest version of 3DxWare
Re: Problem with TopSolid7.17, SpaceMouse Enterprise, and latest version of 3DxWare
https://3dconnexion.com/us/applications ... -topsolid/
https://3dconnexion.com/us/archived-dri ... s-10-64bit
Try a previous version after 10.8.12 that supports TopSolid v7.17.400.000 and later:Tested TopSolid version:7.17.400.000
Tested 3DxWare version:10.8.12
Supported Platforms:Windows
Compatible since TopSolid version:2023
Hello Brian,
I think that is a problem with the cfg file for TopSolid.
I can send you something to try.
Is you registered email correct (info@...)?
There is an error in the TopSolid cfg file limited to one or two modes of TopSolid.
It has been fixed for the next release.
If anyone wants the fixed file before then, PM me.
Thanks again for your help, Jim!
HNY to you folks!
Cheers, Brian
HNY to you folks!
Cheers, Brian
Hey @jwick
I have that problem and i cant PM you couse of new membership. Can you help me?
Are you using the latest driver version? Currently, it is version 10.8.20 and is available for download from here.
I do.
Thats all ive got in button setting.
- setting.png (107.58 KiB) Viewed 8254 times
DannyGraefe
Same problem here with SpaceMouse Enterprise @3DxWare 10.9.6.699 3DxWinCore 17.9.6.21741 in connection with TopSolid 7.19.
The Navigation works perfect and Viewport Management also. But the 12 Keys with LCD-Screen do not work. I can configure them that Program Icon - for example key 1 as a specific TopSolid task choosen in 3Dx Menue capture - but when I press then cames the VirtualNumPad witch is the default function on Key 1 otherways. same with other Keys.
Has anyone solved the Key using get correct to work on TopSolid. >> If it will work it could the swiss knife for 3DCADCAM
