Problem with TopSolid7.17, SpaceMouse Enterprise, and latest version of 3DxWare
SDNM
Post by SDNM »
Hi everybody:
It seems that there is a problem with the latest version of the 3DxWare driver (10.8.17.3666) and the SME when used in TopSolid 7.17. The view manipulation keys do not work in a TopSolid Assembly document for some reason. They do work in other document types.
Is anyone else experiencing this behavior?
Cheers, Brian
Re: Problem with TopSolid7.17, SpaceMouse Enterprise, and latest version of 3DxWare
https://3dconnexion.com/us/applications ... -topsolid/
Tested TopSolid version:7.17.400.000
Tested 3DxWare version:10.8.12
Supported Platforms:Windows
Compatible since TopSolid version:2023
Try a previous version after 10.8.12 that supports TopSolid v7.17.400.000 and later:
https://3dconnexion.com/us/archived-dri ... s-10-64bit
Hello Brian,
I think that is a problem with the cfg file for TopSolid.
I can send you something to try.
Is you registered email correct (info@...)?
SDNM
Post by SDNM »
jwick wrote: ↑Tue Dec 19, 2023 12:07 am Hello Brian,
Hi jwick:
Thanks for your note-yes, "info@..." should do the trick.
Cheers, Brian
There is an error in the TopSolid cfg file limited to one or two modes of TopSolid.
It has been fixed for the next release.
If anyone wants the fixed file before then, PM me.
SDNM
Post by SDNM »
Thanks again for your help, Jim!
HNY to you folks!
Cheers, Brian
JaPik
Post by JaPik »
Hey @jwick
I have that problem and i cant PM you couse of new membership. Can you help me?
JaPik wrote: ↑Thu Apr 18, 2024 1:16 pm Can you help me?
Are you using the latest driver version? Currently, it is version 10.8.20 and is available for download from here.
JaPik
Post by JaPik »
I do.
Thats all ive got in button setting.
DannyGraefe
Post by DannyGraefe »
Same problem here with SpaceMouse Enterprise @3DxWare 10.9.6.699 3DxWinCore 17.9.6.21741 in connection with TopSolid 7.19.
The Navigation works perfect and Viewport Management also. But the 12 Keys with LCD-Screen do not work. I can configure them that Program Icon - for example key 1 as a specific TopSolid task choosen in 3Dx Menue capture - but when I press then cames the VirtualNumPad witch is the default function on Key 1 otherways. same with other Keys.
Has anyone solved the Key using get correct to work on TopSolid. >> If it will work it could the swiss knife for 3DCADCAM
