Ver. 10.8.3 cannot be installed
db11
Re: Ver. 10.8.3 cannot be installed
Post by db11 »
StefanV wrote: Wed Jul 17, 2024 7:12 am After contacting support I managed to install the latest version (10.8.4). Cheers to them for helping out with this!
These are the steps, but please do it only if you understand the implications. You will temporarily lower the security of your system..
This is crazy that you have to mess around in Terminal and disable system integrity protection simply to install a device driver!
Is this a result of system security changes with Sonoma? Surely there must be a better/safer solution to these Installer hangs.
stuff
Post by stuff »
Had to login simply to respond to this fiasco.
What a joke.
3dconnexion and maybe 3 or 4 small others are a constant pain when dealing with their software/drivers.
DEREK W HOLIMAN
benkitesurfs
Post by benkitesurfs »
Thanks for this! I finally got this working.
I would like to add a small clarification that I got hung up on:
SIP must be enabled/disabled from recovery mode
systemextensionsctl must be run in regular startup mode - it will not run in recovery mode.
I did not understand this and was really frustrated that systemextensionsctl was not working...
