MacOS 14.6.1
Clarin
MacOS 14.6.1
Post by Clarin »
3D Space Mouse is not compatible with the official release of MacOS 14.6.1
Where is the update? I can only find 14.8.4 and it doesn't work
AmroSalih
Re: MacOS 14.6.1
Post by AmroSalih »
Is there an an issue or error during the installation of the 3DxWare driver?
skmiec
Re: MacOS 14.6.1
Post by skmiec »
Hi Clarin
Our newest official driver is 10.8.4.
Can you please provie how this happened?
Did you update your macOS from previous version to 14.6.1 was 3Dconnexion driver already installed?
Clarin
Re: MacOS 14.6.1
Post by Clarin »
My space mouse stoped working properly (it acts like a somewhat of normal mouse now) since I did the 14.6.1 update.
I tried to reinstall the driver and the 10.8.4 just hangs during the install and I have to hard restart to cancel the process.
I have also de-install the driver to no avail.
Hope this helps, best,
Clarin
slbaumgartner
Re: MacOS 14.6.1
Post by slbaumgartner »
My USB wired space mouse is working under macOS 14.6.1 with one annoying issue: every time the Mac sleeps or I close SketchUp, it loses the connection to the space mouse. Recovery is to unplug space mouse and then plug it in again, at which point it behaves normally until the next time. The Driver is 10.8.4.
Clarin
Re: MacOS 14.6.1
Post by Clarin »
I have tried multiples times to re-install the drivers, and it just hangup with "running package scripts....."
What can I do??? Please help, thanks
benkitesurfs
Re: MacOS 14.6.1
Post by benkitesurfs »
I'm having exactly the same problem. The software will not install. It hangs at "Running Package Scripts". It's extra annoying because I can't quit the installer, and as a result, MacOS won't let me restart the computer. So the only way to end the process is to hard shut down by holding the power button.
Screenshot 2024-08-30 at 08.36.31.png (54.68 KiB) Viewed 13703 times
skmiec
Re: MacOS 14.6.1
Post by skmiec »
Hi benkitesurfs
Please have a look at this post.
There is a solution how to overcome this problem
benkitesurfs
Re: MacOS 14.6.1
Thanks! That worked for me.
