Problem with the WM_INPUT exemple
gmobile
Post by gmobile »
When i run your WM_INPUT exemple, GetRawInputData() fails on line 142 in WM_INPUTExample.cpp. The WM_INPUT method is the best way i can make use of a 3dx device in my application.
Is there a solution to this problem?
Thank you
Gabriel
Works for me.
What error are you getting?
Which device do you have connected?
What O/S, version, etc. are you running?
Did you make any modifications to the demo?
gmobile
Post by gmobile »
I didn't make any modification to the code.
Im using the Space Navigator, O/S is Vista x64, and i compiled on VS2005.
GetRawInputData() returns -1 everytime I displace the cap.
I tried on Vista 32bit with the same hardware and its works. So i guess its a problem with the OS. Do you have any clue how i could fix that?
Much appreciated.
Gabriel
Aha. I haven't tried that code on Win64.
Maybe RAWINPUTHEADER is a different size on Win64. You can call GetRawInputData with a null pointer to get the required size.
gmobile
Post by gmobile »
You are right, of course, i just read :
"RAWINPUT is wrong (the fieldoffset(16)) because it wrongly assumes RAWINPUTHEADER being 16 bytes long on all platforms, while may be correct on 32 bit, it's 24 bytes on 64 bit. "
I'll try this as soon as i get home.
Thanks you
For everyone's information, the referenced link:
http://social.msdn.microsoft.com/forums ... 4947f4a009
Isn't the web a wonderful thing?!
