When i run your WM_INPUT exemple, GetRawInputData() fails on line 142 in WM_INPUTExample.cpp. The WM_INPUT method is the best way i can make use of a 3dx device in my application.
Is there a solution to this problem?
Thank you
Gabriel
Problem with the WM_INPUT exemple
I didn't make any modification to the code.
Im using the Space Navigator, O/S is Vista x64, and i compiled on VS2005.
GetRawInputData() returns -1 everytime I displace the cap.
I tried on Vista 32bit with the same hardware and its works. So i guess its a problem with the OS. Do you have any clue how i could fix that?
Much appreciated.
Gabriel
Much appreciated.
Gabriel
For everyone's information, the referenced link:
http://social.msdn.microsoft.com/forums ... 4947f4a009
Isn't the web a wonderful thing?!
