I have a problem with side buttons response.
I use side buttons as "copy"/"paste" a lot in all applications.
Unfortunately sometimes, clicking in copy button and paste after, it inserys previously copied selection.
Side buttons reactivity
Re: Side buttons reactivity
Hi sokolyk
Can you please share in what application do you see this problem and which version of the driver do you use?
Indeed, stupid mistake, the driver wasn't updated. With 3DxWare 10.9.6.699 there is no issue with one-click copy.
Post can be closed
Post can be closed
I recently encountered this problem again.
I meant exmaples of application where you see the problem.
I found the reason.
The problem in delay between the actions "highlight text" -> "click "copy button" -> "switch window" -> "click "paste" button".
If you do everything quickly as I used to, copy doesn't work
If you wait 1 sec between each action, it works.
It works as well, if you doubleclick "copy" button
