Side buttons reactivity
sokolyk
Post by sokolyk »
I have a problem with side buttons response.
I use side buttons as "copy"/"paste" a lot in all applications.
Unfortunately sometimes, clicking in copy button and paste after, it inserys previously copied selection.
skmiec
Re: Side buttons reactivity
Post by skmiec »
Hi sokolyk
Can you please share in what application do you see this problem and which version of the driver do you use?
sokolyk
Post by sokolyk »
Indeed, stupid mistake, the driver wasn't updated. With 3DxWare 10.9.6.699 there is no issue with one-click copy.
Post can be closed
sokolyk
Post by sokolyk »
I recently encountered this problem again.
sokolyk
Post by sokolyk »
skmiec wrote: Mon Jul 07, 2025 10:50 pm Hi sokolyk
The driver's versions
3DxWare 10.9.6.699
3DxWinCore 17.9.6.21741
Driver reboot and system reboot don't help
skmiec
Post by skmiec »
I meant exmaples of application where you see the problem.
sokolyk
Post by sokolyk »
skmiec wrote: Tue Jul 22, 2025 10:40 pm I meant exmaples of application where you see the problem.
I found the reason.
The problem in delay between the actions "highlight text" -> "click "copy button" -> "switch window" -> "click "paste" button".
If you do everything quickly as I used to, copy doesn't work
If you wait 1 sec between each action, it works.
It works as well, if you doubleclick "copy" button
sokolyk
Post by sokolyk »
I forgot to mention that it doesn't matter what app you use, the behaviour is the same
