LCD Display
[email protected]
LCD Display
Hi. Since loading windows 11 my Enterpise LCD screen has not been updating when I switch from app to app.Some of the buttons dont want to function in some apps. I have updated the driver. And I have 2 Entrprises 1 at work and 1 at home and they both behaving badly so I dont think its a harware issue. Thanks Eddy.
Re: LCD Display
What's the 3DxWare driver version number in your Windows 11 operating system?
[email protected]
Re: LCD Display
1.6.6.20315 driver version.
Re: LCD Display
Re: LCD Display
The latest 3DxWare version number is 10.9.12. Try updating to this version if you can.
[email protected]
Re: LCD Display
I see there was another later driver but it hasnt helped. Ill try the support clowns.
Thanks Eddy.
Thanks Eddy.
Re: LCD Display
I have a slight malfunction with the Spacemouse Enterprise display on Windows 11 that might be related.
It shows the "welcome screen" so to speak, the blue screen with words, but no application specific displays. The buttons are working alright, application specific. Just the display stays at the "welcome screen". Until maybe an hour later, it suddenly starts to work as normal. Not always, but most of the time.
This behavior was gradually building up the more software was installed on the computer. At first, with a fresh Windows 11 installation, the display worked flawlessly, showing the welcome screen and immediately after that, showed the application specific text fields.
It is not really a problem for me. I know the buttons' functions for my most used applications by heart. This 30-90 minute lag is a sign that the driver is not working properly. Maybe there is a Windows setting to set priority to the 3dx service?
This Windows 11 system of mine is running a lot of services. Dozens of virtual MIDI ports. Quite possible that this not very common system is the cause of the driver's/display's lag.
In cases where I need the display text fields without delay, there's a quick solution: unplug and re-plug the device. It will re-connect, show the welcome screen, and immediately after, the text fields.
Driver is up to date, and the device is directly connected to the computer, without hub.
[email protected]
Re: LCD Display
Hi Phil999
I also had prolonged time with the blue welcome screen.
All issues have gone now
I had the latest spacemouse driver I updated my nviad graphics driver (no imporvement) then reloaded the Enterprise driver and all sorted out.
I seems to be working across all applications now.The squence of graphics driver first then spacemouse driver seems to matter.
Eddy
Eddy
Re: LCD Display
Just to follow up, if you are using Windows 11 OS there are quite a few indications if the SpaceMouse Enterprise displays the splash screen only.[email protected] wrote: ↑Thu Mar 26, 2026 7:39 pm I see there was another later driver but it hasnt helped. Ill try the support clowns.
Thanks Eddy.
Here at Tech Support we solved the issue for clients which is usually caused by, USB ports and their power, Device security settings on Windows, sometimes user permissions. If this really should be due to the 3Dconnexion hardware or software then we'd generate a diagnostic file. We're happy to help.
[email protected]
Re: LCD Display
Unfortunatly the nvida drive first andthen the 3dconnexion drive fix did not last seem to have deteriarated back to not updating.
Feels like windows 11 and 3d connexion are not talking nicely.
Re: LCD Display
This points to a Windows 11 and 3Dconnexion driver conflict rather than faulty hardware, especially since it happens on multiple systems. The temporary fix after reinstall also suggests the driver/service state or install order is what’s breaking it over time.Broken Screen prank
Re: LCD Display
Thank you for the feedback. Windows operating system settings may prevent the 3Dconnexion SpaceMouse Enterprise from being detected correctly. We have received reports from other customers where similar behavior was traced to user profile permissions or system-specific configuration issues rather than a broader driver conflict.brosce wrote: ↑Thu Jun 18, 2026 8:23 am This points to a Windows 11 and 3Dconnexion driver conflict rather than faulty hardware, especially since it happens on multiple systems. The temporary fix after reinstall also suggests the driver/service state or install order is what’s breaking it over time.Broken Screen prank
