No Rotation in AutoCad 2008 with Spacepilot
I have 3dxWare rel: 3.6.11; Driver: 6.6.4; firmware: 3.12, every since I have installed the newer AutoCad 2008 (I have updated twice) the rotations do not work in AutoCad. I never experienced this with older versions. Is there something I am missing?
Thx - Ray
Advanced Setting Tab
Dear admirera,
In the 3Dconnexion Control Panel, under the Advanced Setting Tab, what do you find checked when in the same configuration that you are in when you experience the loss of rotations?
Sincerely,
Bryan
Sincerely,
Bryan
all of the boxes on the left are toggled on in the Advanced setting tab. I have also pressed the 3d button on the device off/on and it doesn't seem to matter.
Thx - Ray
Jet Demo Behavior
Dear admirera,
When you say you have updated twice. Are you talking about AutoCAD 2008 or the 3DxSoftware 3.6.11?
What Operating System do you have?
What behavior do you observe in the Jet Demo?
(Start, All Programs, 3Dconnexion, 3Dconnexion 3DxWare, Demos)
Sincerely,
Bryan
Sincerely,
Bryan
Jet Demo Behavior
I have updated the 3-d connection software twice.
The only application that does not rotate is AutoCad 2008. The demo software, Pro-E, Metrology software, all work without a problem. Only Mechanical Desktop 2008. If I try to rotate, the CS icon turns to Red, blue & green larger 3-d icon, but it never rotates in 3-d space. I have been able to play with the 3-d navigation and get some things to rotate, but they seem to be completely different that what I get with Pro-E or other applications that I use the Space Pilot for.
Thx - Ray
Which Mode
None of the modes that I have tried appear to work inside AutoCAD 2008 like I had previously.
Thx - Ray
Which Visual Modes?
Dear admirera,
Under the 'View Menu' in Autocad, you should have a listing for 'Visual Mode'. Which Visual Mode are you in when having trouble rotating? Switch from 2D to 3D mode to allow the rotation to work.
Sincerely,
Bryan G.
Sincerely,
Bryan G.
kevkersting
Space Explorer also not working with Mechanical Desktop 2008
I seem to be having the same issue.
I just recieved my Space Explorer & installed it a few minutes ago. I can't seem to get it to work inside Autocad.
It works fine in Solid Works 2009 Pro.
I installed the latest driver off the web site when I first installed.
Thank you for any help.
kevkersting
You can also just switch to another visual style:
UPDATE:
Maybe this Knowledgebase Article will also help you.
View->Visual Styles->WireframeMaybe this Knowledgebase Article will also help you.
Robert Stadie
