My Specs:
ATI FirePro v8700, Driver:FirePro_v8700_8.603_XP32_79796.exe
Spacepilot, Driver: 3.7.16
OS: Windows XP Pro
Computer: Core 2 Duo 2.4 GHz, 3GB RAM
I have been using 3D connexion devices for a while now. Currently I'm using the Spacepilot alongside of Hypermesh v9.0 and v10.0 . Both versions rotate/move very cleanly using my regular mouse and the built-in keyboard shortcuts.
In simple models without surface meshing elements everything runs fine both with the keyboard/mouse and the spacepilot.
However, when I add surface meshing elements up to around 2 million+, the Spacepilot rotations are very jerky and not fluid in the least bit. The keyboard/mouse combination still works very fluidly.
My graphics card is a brand new ATI FirePro v8700 with the latest drivers, so I am sure that is not the limiting issue. It appears that the way 3dConnexion talks with Hypermesh is inefficient and the high element count pushes this issue forward.
Is there a fix to this stuttering problem?
Spacepilot slow response times in Hypermesh v9.0
Re: Spacepilot slow response times in Hypermesh v9.0
Hi biohzrd,
I am afraid you need to address this issue with the manufacturer of Hypermesh, with Altair. The support for the 3D mouse was implemented by Altair; we have no access to the sources. Please contact Altair and let us know what you learn.
Uta Ludwig
Uta Ludwig
I don't think it is your app. I have the exact problem in Max2010 and I have a FireGL V8600. Maybe it's the card but I don't think so. These are hot cards with lots of memory. Your card has 2GB to my 1GB.
I have a file with 240,000 faces and 460 objects. It rotates just fine with the mouse but the Space Pilot won't rotate at all. It's like it's frozen. If I isolate just a few objects it will rotate them but it's jerky.
Asus P5K-Deluxe - Intel Core2 Extreme QX6850 - 4GB DDR2 1066Mhz -ATI FireGL V8600 - 3D Studio (preMax) thru Max 2010 Design
3ds Max 2025, GIGABYTE X570 AORUS x570 Motherboard, Ryzen 9 3950x, 128 GB G.SKILL Trident Z Neo DDR4, Sabrent Rocket NVMe 4.0 M.2 drives, NVidia RTX 4090, Spacemouse Pro Wireless, Windows 11 Pro x64, Tri-Monitor
Yes, I believe so. When I open the 'Control Panel' it reports:
Release Version 3.7.12
(Driver Version: 6.7.11)
Firmware Version: 3.12
Device Type: SpacePilot (we know this already)
Actually, I just checked. Apparently 3.7.18 was released 'Today.' I'll update and see if it helps.
