I am using Inventor 2010 and Autocad 2008. I frequently have both apps open at the same time. If I am using Inventor and I switch over to Autocad, it cause 3dxWare to crash very frequently. Not every time, but I rarely go more then 3 or 4 times of doing this without crashing. This then causes Inventor to become very sloooowwwww until I close and restart. Depending on how many graphic windows were open in Inventor at the time, it can take 5-10 minutes to close Inventor.
I can avoid the crash by switching to some other application (usually just windows explorer) in between Inventor and Autocad. But it's hard to remember to do this. Any thoughts? I just updated the 3dxWare software and got a crash on the first try.
Switching between Inventor and Autocad windows causes crash
Dear tims,
What release version of 3DxSoftware do you have installed?
(3Dconnexion Control Panel, Help, About)
When you say switching over to AutoCAD causes 3DxWare to crash, what do you experience? Does your hardware power down? Does your Windows operatings system get a stop error? Do you get someother kind of error. Does one of your applications develop a 'not responding error?'
What Windows Operating System are you using?
What are your machine specs?
Did you have a previous installation that was more successful?
Which of our devices are you using?
Sincerely,
Bryan
Sincerely,
Bryan
What happens is I’m using Inventor, I go down to the taskbar and click on the Autocad application. Then a message box pops up: “3DxWare: An unhandled exception occurred in your 3DxWare driver session, would you like to save a diagnostic file?” I usually say no. Then windows asks if I want to send them information about the problem, again I usually say no. But now, even if I restart the 3Dx driver, I need to have the driver running before I start Inventor in order for the device to work. So I have to close and restart Inventor as well. And Inventor is painfully slow until I get it restarted.
3DxSoftware
Release Version: 3.10.1
Driver Version: 6.10.0
Firmware Version: 3.18
Device Type: Space Explorer
Windows Vista Business
2GB Ram
NVidia Quadro FX 3450/4000 SDI
256MB Ram
Driver Version: 7.15.11.8120
Did I have a previous installation that was more successful? Previous installation of which software, 3Dx, Inventor, or Autocad? I would say yes, because it didn’t always do this. But it’s been doing it for so long, I don’t recall exactly when it started. At least a year ago.
I am using a space explorer USB.
This is the windows error reporting message from my last crash:
5/5/2010 4:58 PM Application Error Faulting application 3dxsrv.exe, version 16.10.0.0, time stamp 0x4b7ae2ee, faulting module udui.dll, version 2.18.0.0, time stamp 0x4b7ae2a4, exception code 0xc0000005, fault offset 0x00031274, process id 0x948, application start time 0x01caec732351fee0.
5/5/2010 4:58 PM Windows Error Reporting Fault bucket 1846575928, type 1
Event Name: APPCRASH
Response: None
Cab Id: 0
Problem signature:
P1: 3dxsrv.exe
P2: 16.10.0.0
P3: 4b7ae2ee
P4: udui.dll
P5: 2.18.0.0
P6: 4b7ae2a4
P7: c0000005
P8: 00031274
P9:
P10:
C:\Users\gtims\AppData\Local\Temp\WER80C9.tmp.version.txt
These files may be available here:
C:\Users\gtims\AppData\Local\Microsoft\Windows\WER\ReportArchive\Report0e1c938e
Hope this helps.
3DxSoftware
2GB Ram
256MB Ram
Response: None
Cab Id: 0
Problem signature:
P1: 3dxsrv.exe
P2: 16.10.0.0
P3: 4b7ae2ee
P4: udui.dll
P5: 2.18.0.0
P6: 4b7ae2a4
P7: c0000005
P8: 00031274
P9:
P10:
Hope this helps.
Hello tims,
Next time it crashes, please allow it to save the "diagnostic file" and send it to us. It lists the name and location of the file when it writes it.
Also, at that time, make a copy of your saved .scg files. And include them. I suspect one of them may be corrupt. Those are saved in %APPDATA%\3Dconnexion\3DxWare\profiles.
I'll send you a PM with the email address.
Thanks.
Jim
3DxSoftware Development
Thanks.
Jim
