Hi Bryan
Thanks for fast reply
Yes - I found out about the users and configurations.
I have 4 users in the Control Panel.
Any application
Jesper
Inventor
Inventor - Jesper
The settings for each profile is adjustable independently. But if I set up the profil called Any application and switch to the Inventor profile and back, the settings is reset. Overall speed, Zoom direction and the button config is affected.
If I open Inventor and works in the environment its all good until I create or edit a sketch. The the settings is changed. Until I exit the sketch again. Then they are back to normal.
I've tried to edit a sketch and while being in the sketch go to control panel and change my settings. And it works - until next time I enter a sketch...
So my work is being interrupted everytime I create og edit a sketch, by the need to open control panel, change settings and going back to Inventor again. I'm getting prety fast at it
But still... I could save enormous amounts of time (and irritation) if it would work properly...
If it helps:
Release Version: 3.10.1
(Driver version 6.10.0)
Firmwave version: 4.04
Device type: SpaceNavigatior
I got an error-message during installation of the driver:
Error 1327. Invalid drive Z:
And later in the installation the error changed to 1306 (AFAIR... or was is 1106? - something ending on 6
I managed to install the driver anyway, and it works like it did in XP. So I don't think this has anything to do with the behavior of the control panel..
/J
