I might have a little problem here and I am not sure if it's space nav. or it's just a coincidence. I found some similar issues in the forum but no mention of this.
I am using NX on Win 7. When I use a command like "Chamfer" in NX, program enlightens the objects when the cursor above them so that I can see which object will be selected when I click to left mouse button.
NX doesn't enlighten the object anymore since the driver locked. However it says which object will be selected on the status bar and when I click on the object, it selects it. It just doesn't enlighten the object prior to selection. When I hover the cursor over the object several times, it enlightens it, though.
I had a similar issue in Cimatron on Win XP. When I used the space nav. in Cimatron, it didn't enlighten the object nor it selects it. When I didn't use space nav. and just use the mouse to zoom, rotate and pan, it worked as it supposed to be. I updated the 3dx driver, it didn't help.
I didn't pay much attention in that time because I was about to upgrade the system.
Now, even if I didn't use space nav. in NX, preselection issue still happens. The issue in NX is not a killing one but it disturbs me anyway.
Any thoughts?
