Trying to use csMonitor code
Hightree
Post by Hightree »
Hi there,
I'm trying to use the C# example inside of Unity3D.
Unfortunately when trying to hook up the callback functions, I get the following error code :
NotSupportedException: non imported interfaces on imported classes is not yet implemented.
(wrapper cominterop) TDx.TDxInput._ISensorEvents_Event:add_SensorInput (TDx.TDxInput._ISensorEvents_SensorInputEventHandler)
I'm no interop or COM ninja, does anybody have any ideas on how to get round this ?
Thanks in advance, Patrick
Hit any user to continue.
Here is a Unity3D plugin for the SpaceNavigator:
http://forum.unity3d.com/threads/130907 ... eNavigator...)
Hightree
Post by Hightree »
Thanks for the pointer, I found the plugin too this weekend.
But the programmer in me wants to write this plugin himself ;)
ljdp
Re: Trying to use csMonitor code
Post by ljdp »
I'm getting the same error and i'd also like to know how to resolve this, that plugin for unity costs $70 which is priced way to high for me.
Hightree
Post by Hightree »
In the end I got it working by using the code from that sample, but leaving out the COM event stuff.
Instead I am polling the device for its current values in my EditorWindow's Update function.
My plugin is functional by now and I am planning to open source it soon.
It just needs to be cleaned up a bit, should be done within a couple of weeks.
P.S.
I should have posted the solution when I found it, sorry for that.
batigol
Post by batigol »
Hi Hightree, could you give any tip for get data in Update function?
In C# sample, I could remove all event and get data when ever I want. But in Unity, I try to get data in Update function, but it always zero :(
Hightree
Post by Hightree »
Strange, maybe there's something going wrong in the initialization phase.
Here's my windows implementation of the device handling:
using System;
using System.Runtime.InteropServices;
using TDx.TDxInput;
using UnityEngine;
class SpaceNavigatorWindows : SpaceNavigator {
	// Public API
	public override Vector3 GetTranslation() {
		float sensitivity = Application.isPlaying ? PlayTransSens : TransSens;
		return (SubInstance._sensor == null ?
			Vector3.zero :
			new Vector3(
				LockTranslationX || LockTranslationAll ? 0 : (float)SubInstance._sensor.Translation.X,
				LockTranslationY || LockTranslationAll ? 0 : (float)SubInstance._sensor.Translation.Y,
				LockTranslationZ || LockTranslationAll ? 0 : -(float)SubInstance._sensor.Translation.Z) *
				sensitivity * TransSensScale);
	public override Quaternion GetRotation() {
		float sensitivity = Application.isPlaying ? PlayRotSens : RotSens;
			Quaternion.identity :
			Quaternion.AngleAxis(
				(float)SubInstance._sensor.Rotation.Angle * sensitivity * RotSensScale,
				new Vector3(
					LockRotationX || LockRotationAll ? 0 : -(float)SubInstance._sensor.Rotation.X,
					LockRotationY || LockRotationAll ? 0 : -(float)SubInstance._sensor.Rotation.Y,
					LockRotationZ || LockRotationAll ? 0 : (float)SubInstance._sensor.Rotation.Z)));
	// Device variables
	private readonly Sensor _sensor;
	private readonly Device _device;
	//private readonly Keyboard _keyboard;
	#region - Singleton -
	/// <summary>
	/// Private constructor, prevents a default instance of the <see cref="SpaceNavigatorWindows" /> class from being created.
	/// </summary>
	private SpaceNavigatorWindows() {
		try {
			if (_device == null) {
				_device = new DeviceClass();
				_sensor = _device.Sensor;
				//_keyboard = _device.Keyboard;
			if (!_device.IsConnected)
				_device.Connect();
		catch (COMException ex) {
			Debug.LogError(ex.ToString());
	public static SpaceNavigatorWindows SubInstance {
		get { return _subInstance ?? (_subInstance = new SpaceNavigatorWindows()); }
	private static SpaceNavigatorWindows _subInstance;
	#endregion - Singleton -
	#region - IDisposable -
	public override void Dispose() {
		try {
			if (_device != null && _device.IsConnected) {
				_device.Disconnect();
				_subInstance = null;
				GC.Collect();
	#endregion - IDisposable -
Hope this helps.
batigol
Post by batigol »
Thanks Hightree, your code help he to easy get value in Unity3D, just add close connection at onQuit :)
Here is my code, hope this helpful for someone
using UnityEngine;
using System.Collections;
using System;
using TDx.TDxInput;
public class SpaceNavigator : MonoBehaviour {
	private Sensor sensor;
	private Device device;
	private Keyboard keyboard;
	void Start () {
        sensor = device.Sensor;
        keyboard = this.device.Keyboard;
        device.Connect();
	void Update () {
		var translation = sensor.Translation;
		var rotation = sensor.Rotation;
		Debug.Log("tx: "+(translation.X*1000.0).ToString()+",ty: "+translation.Y.ToString()+",tz: "+translation.Z.ToString());
		Debug.Log("rx: "+rotation.X.ToString()+",ry: "+rotation.Y.ToString()+",rz: "+rotation.Z.ToString()+",rs: "+rotation.Angle.ToString());
        System.GC.Collect();
    void OnApplicationQuit() {
         if (device != null && device.IsConnected) {
            GC.Collect();
Hightree
Post by Hightree »
My driver is functional and released out into the wild :)
I've published it here on the Unity forum and the source code is available on Github.
