Hightree
Posts: 20 Joined: Fri May 11, 2007 1:09 am
Post
by Hightree » Sat Aug 07, 2010 11:59 am
Hi there,
I'm trying to use the C# example inside of
Unity3D .
Unfortunately when trying to hook up the callback functions, I get the following error code :
NotSupportedException: non imported interfaces on imported classes is not yet implemented.
(wrapper cominterop) TDx.TDxInput._ISensorEvents_Event:add_SensorInput (TDx.TDxInput._ISensorEvents_SensorInputEventHandler)
I'm no interop or COM ninja, does anybody have any ideas on how to get round this ?
Thanks in advance, Patrick
Hit any user to continue.
Posts: 3455 Joined: Wed Dec 20, 2006 2:25 pm
Post
by jwick » Mon Apr 09, 2012 7:23 am
Hightree
Post
by Hightree » Tue Apr 10, 2012 1:12 am
Thanks for the pointer, I found the plugin too this weekend.
But the programmer in me wants to write this plugin himself
ljdp
Posts: 1 Joined: Sat Feb 23, 2013 12:03 pm
Post
by ljdp » Sat Feb 23, 2013 12:05 pm
I'm getting the same error and i'd also like to know how to resolve this, that plugin for unity costs $70 which is priced way to high for me.
Hightree
Post
by Hightree » Mon Feb 25, 2013 2:06 am
In the end I got it working by using the code from that sample, but leaving out the COM event stuff.
Instead I am polling the device for its current values in my EditorWindow's Update function.
My plugin is functional by now and I am planning to open source it soon.
It just needs to be cleaned up a bit, should be done within a couple of weeks.
P.S.
I should have posted the solution when I found it, sorry for that.
batigol
Posts: 19 Joined: Wed May 08, 2013 8:10 pm
Post
by batigol » Sun May 12, 2013 9:00 pm
Hi Hightree, could you give any tip for get data in Update function?
In C# sample, I could remove all event and get data when ever I want. But in Unity, I try to get data in Update function, but it always zero
Hightree
Post
by Hightree » Mon May 13, 2013 1:46 am
Strange, maybe there's something going wrong in the initialization phase.
Here's my windows implementation of the device handling:
using System;
using System.Runtime.InteropServices;
using TDx.TDxInput;
using UnityEngine;
class SpaceNavigatorWindows : SpaceNavigator {
// Public API
public override Vector3 GetTranslation() {
float sensitivity = Application.isPlaying ? PlayTransSens : TransSens;
return (SubInstance._sensor == null ?
Vector3.zero :
new Vector3(
LockTranslationX || LockTranslationAll ? 0 : (float)SubInstance._sensor.Translation.X,
LockTranslationY || LockTranslationAll ? 0 : (float)SubInstance._sensor.Translation.Y,
LockTranslationZ || LockTranslationAll ? 0 : -(float)SubInstance._sensor.Translation.Z) *
sensitivity * TransSensScale);
public override Quaternion GetRotation() {
float sensitivity = Application.isPlaying ? PlayRotSens : RotSens;
Quaternion.identity :
Quaternion.AngleAxis(
(float)SubInstance._sensor.Rotation.Angle * sensitivity * RotSensScale,
new Vector3(
LockRotationX || LockRotationAll ? 0 : -(float)SubInstance._sensor.Rotation.X,
LockRotationY || LockRotationAll ? 0 : -(float)SubInstance._sensor.Rotation.Y,
LockRotationZ || LockRotationAll ? 0 : (float)SubInstance._sensor.Rotation.Z)));
// Device variables
private readonly Sensor _sensor;
private readonly Device _device;
//private readonly Keyboard _keyboard;
#region - Singleton -
/// <summary>
/// Private constructor, prevents a default instance of the <see cref="SpaceNavigatorWindows" /> class from being created.
/// </summary>
private SpaceNavigatorWindows() {
try {
if (_device == null) {
_device = new DeviceClass();
_sensor = _device.Sensor;
//_keyboard = _device.Keyboard;
if (!_device.IsConnected)
_device.Connect();
catch (COMException ex) {
Debug.LogError(ex.ToString());
public static SpaceNavigatorWindows SubInstance {
get { return _subInstance ?? (_subInstance = new SpaceNavigatorWindows()); }
private static SpaceNavigatorWindows _subInstance;
#endregion - Singleton -
#region - IDisposable -
public override void Dispose() {
try {
if (_device != null && _device.IsConnected) {
_device.Disconnect();
_subInstance = null;
GC.Collect();
#endregion - IDisposable -
Hope this helps.
batigol
Post
by batigol » Mon May 13, 2013 2:51 am
Thanks Hightree, your code help he to easy get value in Unity3D, just add close connection at onQuit
Here is my code, hope this helpful for someone
using UnityEngine;
using System.Collections;
using System;
using TDx.TDxInput;
public class SpaceNavigator : MonoBehaviour {
private Sensor sensor;
private Device device;
private Keyboard keyboard;
void Start () {
sensor = device.Sensor;
keyboard = this.device.Keyboard;
device.Connect();
void Update () {
var translation = sensor.Translation;
var rotation = sensor.Rotation;
Debug.Log("tx: "+(translation.X*1000.0).ToString()+",ty: "+translation.Y.ToString()+",tz: "+translation.Z.ToString());
Debug.Log("rx: "+rotation.X.ToString()+",ry: "+rotation.Y.ToString()+",rz: "+rotation.Z.ToString()+",rs: "+rotation.Angle.ToString());
System.GC.Collect();
void OnApplicationQuit() {
if (device != null && device.IsConnected) {
GC.Collect();
Hightree
Post
by Hightree » Mon May 20, 2013 8:23 am
My driver is functional and released out into the wild
I've published it
here on the Unity forum and the source code is available on
Github .
