on maya 2013 sp2
Abishai
on maya 2013 sp2
Post by Abishai »
Hello! let me go straight to the problem:
Fact is that I've been unable to use my Spacepilot pro for a while inside maya. I've tried reinstalling, uninstalling, deleteing maya & 3dx preferences... etc... without result. I've searched these forums looking for solutions and tried everything I could find. Everytime I start Maya I get this error in the console on 3dx plugin load:
// Error: //
// Error: Line 0.38: "$gMagellanMoveMode" is an undeclared variable. //
// Error: //
// Error: Line 0.46: "$gMagellanRotationMode" is an undeclared variable. //
// Error: //
// Error: Line 0.38: "$g3DxSuspendMotion" is an undeclared variable. //
// Error: //
// Error: Line 0.44: "$gMagellanDisableRoll" is an undeclared variable. //
// Error: //
// Error: Line 0.42: "$gMagellan3DViewLock" is an undeclared variable. //
// Error: //
// Error: Line 0.48: "$gMagellanObjectControl" is an undeclared variable. //
// Error: //
// Error: Line 0.62: "$gbMagellanEnableMotionCapture" is an undeclared variable. //
I think its not the first time someone asks, I tried beta 3dxlabs drivers as well for same effect. Please... I'm a bit desperate
Re: on maya 2013 sp2
Hi Abishai,
Please see if the posts strating from here help you resolve the problem.
Abishai
Post by Abishai »
Hi thanks!
thats exactly the thread I followed, I used to lauch it manually by typing MagellanStartup at the console and everything was fine.
The only thing I did was launching Maya with admin rights over a week ago. I read somewhere that 3dconnexion plugin needed admin rights as well if that was the case, so I did, but to me, (no changes at all) it looks more like if it was looking for the plugin scripts on the wrong place.
Today I tried the mouse at work and it worked just fine, as it should. At home I've tried erasing all maya prefs folder, starting over... nothing changed :(
Hi Abishai,
None of our plug-in software requires admin (elevated) privileges. Only the installer and a few others tools (which are not necessary for day-to-day usage of 3D mice) require elevation.
Have you tried running the "repair" of the software? This ought to help with plug-in installations. Go to the Control Panel > Programs > Uninstall a Programs and select "3Dconnexion 3DxSoftware". Then click "Change" and follow the instructions to "Repair" the software. You can also simply start the installer package (which will take it you straight to the "Modify, repair or remove" panel).
Also, make sure you have the latest 3Dconnexion software for your device. You can download the software from here.
Abishai
Post by Abishai »
reinstalled the driver, repaired it as suggested, used the wizard inside... now I have no error, now looks like maya doesnt recognize de device anymore (shows blank on the 3d connexion menu - hotkeys) the puzzle works fine, though
Hi Abishai,
Are you running Maya as an admin (elevated) user?
Abishai
Post by Abishai »
I was running it as regular user, but trying to do it as admin takes me to the first error results on console, what is bugging me is that it wont awnser even to 3d coat anymore as well, but its working fine within the puzzle :S
I didn't mean to ask to run Maya as admin. Quite contrary: you should always run as the logged in user, non-elevated.
Can you try going through all the demos in the "3Dconnexion" Start menu folder? Some will use the exact same API to get 3D mouse data this may shed some light. If one does not work, we will need to have a look at the driver log.
Abishai
Post by Abishai »
Ok I'll give it a try tonight, btw I assume the device should be connected to an USB 2.0, right? Do you know if plugging it into a 1.0 or 3.0 could modify its intended behaviour in some way?
Hi Abishai,
It should work fine with whatever you connected it to (I think USB 1.0 won't but 1.1 will which is probably what you have anyway).
Abishai
Post by Abishai »
Ok I tried uninstalling/reinstalling maya after cleaning all registry entries related to it and that made the mouse work again, Still only works if the mouse is plugged on to a particular USB :shock: and not always along the same session (without restarting the system)
Abishai wrote: Still only works if the mouse is plugged on to a particular USB
What do you mean "only works"? Does it work with Maya on a that single port?
