Just got the spacenavigator- it is awesome as I knew it would be...still getting used to it though.
Anyway I have a couple of questions if anyone could help
1) This is for Rhino but could apply to any other 3d program: Is there a way to configure the 3d mouse to change profiles (or internally within rhino) such that when entering 2D orthographic views (top, left, etc.) it changes to a different configuration? I would ideally like to be able to use it like a joystick, which is different from the config during perspective views. I hope that makes sense- I can clarify if needs be.
2) In Rhino for some reason if I am using the spacenavigator and then I move the mouse at the same time, the performance drops and it becomes choppy and laggy. This is not the case in 3ds max and autocad so I guess it is specific to Rhino. Has anyone else had this problem or could suggest a solution?
