Space nav & picture viewer
wroessl
Post by wroessl »
Hi torniaccio,
you tried it within the Windows Explorer (see above)? How many Push Buttons do you see at the bottom of the gray window? Also when 3Dconnexion Picture Viewer isn't installed you should be able to open images inside the Windows explorer (instead of the ListView which shows the files located under the selected folder).
ciao
Wolfgang
Wolfgang
wroessl
Post by wroessl »
Hi Roberto,
as workaround you can try to launch 3DxViewer by commandline. Open a Dos Terminal and go to the installation folder of 3DConnexion Viewer (default: C:\program files\3Dconnexion\3Dconnexion Picture Viewer\).
Check if file shimgxx.dll exists and execute following commandline:
rundll32.exe shimgxx.dll,ImageView_Fullscreen [Full Path to some Picture you want to open]
The Viewer should launch. But we should try to understand the installation problems you have.
ciao
Wolfgang
Wolfgang
torniaccio
Post by torniaccio »
Ciao Wolfgang,
I follow what u said in the last post. And it works.
About the botton in the windows explorer, I would send u a screen capture, but i need an e_mail address to post it.
Ciao roberto
wroessl
Post by wroessl »
Ciao Roberto,
as email address you can use *******************. It would be useful that you write a note at this forum after posting the screenshot to *******************.
Thanks, ciao
Wolfgang
Edit: hide E-mail address
torniaccio
Ciao wolfgang,
I've send the screenshot.
Ciao Roberto.
wroessl
Post by wroessl »
Ciao Roberto,
thanks for the screenshot, something went completely wrong with your installation. Would you be so kind to check following registry entries (via regedit.exe) . Check if the keys are existing and send me the values.
HKEY_CLASSES_ROOT\Applications\shimgxx.dll\command
and
HKEY_CLASSES_ROOT\CLSID\{50F16B26-467E-11D1-8271-00C04FC3183B\InprocServer32}
Wolfgang
torniaccio
Ciao Wolf.
I think that will be better if u give me again an address where i can send some screenshot (I've missed it)
Anyway my strings are different from yours.
torniaccio
Hi guys
please don’t leave me alone!
I need picture viewer!
Thanks, Ciao,
Roberto
Hi torniaccio,
You're not alone. Please bear with us.
torniaccio
Hi guys,
some news.
here is what I've tried, with an error message, that i hope, will help u to find a solution.
-firewall swiched off
-antivirus swiched off
-removed all 3dx sw
-system rebooted
-3dx sw installed by original CD
-autocad plug in installed (from extras)
tring to "open with" a picture (JPEG), and in the sw list finally appear "3dx pic. view." BUT a windows error message say "c:\aaa.jpg it is not a valid application of WIN32".
Than I've do so,
-update sw by downloaded driver
-reboot pc
and when I tried to "open with" a picture (JPEG) the "3dx pic. view." there was no more listed.
Any idea?
Ciao Roberto
wroessl
Post by wroessl »
Hi torniaccio,
I would need some more information from your registry. I think it would be best you extract the relevant information from the registry by a dos commandline. Three entries would be needed so execute the 3 commandlines each after the other. Each commandline will produce a *.txt file. please send me these 3 files (3Dconnexion.txt, shimgxx.txt, InprocServer.txt).
To produce these files open a Dos Shell, go to a folder where you have write permissions and execute following 3 commandlines:
"reg export HKLM\Software\3Dconnexion 3Dconnexion.txt"
"reg export HKCR\Applications\shimgxx.dll shimgxx.txt"
"reg export HKCR\CLSID\{50F16B26-467E-11D1-8271-00C04FC3183B} InprocServer.txt"
thanks, ciao
Wolfgang
torniaccio
Hi Wolf,
I'm happy to read you again!
I've send u what u need!
Thanks , Ciao
wroessl
Post by wroessl »
Hi torniaccio,
the pathes at the registry for the 3DxViewer are not consistent. There are two different pathes to shimgxx.dll. Please let me know the path or pathes (when shimgxx.dll is located more then once at your folder tree) of shimgxx.dll.
The registry entries are telling me following folders:
C:\Programmi\3Dconnexion\3Dconnexion 3DxSoftware\3DxViewer\shimgxx.dll
and / or
C:\Programmi\3Dconnexion\3Dconnexion Picture Viewer\shimgxx.dll
are both existing? or which of the 2 shimgxx.dll dosen't exist?
thanks, ciao
Wolfgang
torniaccio
Hi wolf,
the second one doesn't exist!!
shimgxx.dll exist only in C:\Programmi\3Dconnexion\3Dconnexion 3DxSoftware\3DxViewer\shimgxx.dll
Thanks Ciao, Roberto
torniaccio
Hi guys!
Do u have some good news for me?
I'm waiting ...
Ciao!
