I have 2 workstations with a SpacePilot at each computer
First computer has Inventor 2008 and 3dsmax 2008 installed. If I work in Inventor and start 3dsmax the SpacePilot refuses to work. Even a unplugg/plugg operation will not work.
Second computer has only 3dsmax (9 and 2008) installed and the SpacePilot works in neither of them even after a new driver install. the 3D connexion logo appears on 3dsmax startup but then nothing... BUT!!!! If I have for exempel Internet Explorer active the SpacePilot works in 3dsmax but in the background!!! This is not acceptable after dishing out so much money.
you have to manually copy the 3dxstd.dlu from plugins folder and the 3DxStudio.ms from scripts/startup folder from 3dsmax 9 installation to 3dsmax 2008 folders. it seems to work just fine.
Right know I have 3dsmax 9 running in the background, I have this IE windows in the right side of my screen and max on the left. Of course this IE windows is the active window
