8 sections radial menu barely usable :(
Fyuzinfected
Re: 8 sections radial menu barely usable :(
Post by Fyuzinfected »
In the meantime already released version 10.5.11 and there is no news about this subject.
It is very sad to know that I have paid a high amount for this equipment with such useless functions.
Greetings from Portugal.
Fábio Martins
dnashj33
Post by dnashj33 »
Yeah. It makes the software look half done. Shame. It's otherwise an awesome feature.
antonynealrobinson
Post by antonynealrobinson »
I can confirm that latest driver 10.5.11 still has a problem with 8 section radial menu.
Please, Please & pretty please.
3Dconnexion can you PLEASE fix this radial menu.
Hopefully that should be polite enough for them to fix it.
skoda
Post by skoda »
Suggestion to the developers.
:idea: Why not to use the functionality from SpaceMouse Enterprise for its display? Switch between icons or description if there is not enough space for both at once.
gravanoc
Post by gravanoc »
If you want to edit your XMLs (pretty easy tbh, but inconvenient), look for your 3dx cfg folder (not the roaming one, though you can edit those as well) and open base.xml.
Open that file as an administrator in Notepad (I use Notepad++ but either should work). Ctrl + F to bring up Find... & type in "user_defined" (w/o quotes) then press enter. If you see something that says user_defined_macros.png, you can remove that png reference and it will then show the text name of your macro. You can also substitute a 24×24 png by placing said png in the referenced folder & then using that file name in place of the user_defined_macro.png reference.
Fyuzinfected
Finally!
Thank you my friend!
Fábio Martins
mhoopes
Post by mhoopes »
Thank you! I deleted everything in that Buttonaction from and including <image>...</image>
Michael Hoopes
mhoopes
Post by mhoopes »
By the way, why isn't this the default? I can't imagine a scenario where a user would prefer User_Defined_Macros.png to their own text.
Michael Hoopes
Fyuzinfected
mhoopes wrote: ↑Thu Jan 03, 2019 3:00 pm By the way, why isn't this the default? I can't imagine a scenario where a user would prefer User_Defined_Macros.png to their own text.
Indeed!
Fábio Martins
mhoopes
Post by mhoopes »
So, the User_Defined_Macros.png image is showing up again in my custom radial menu, for no apparent reason. Here's the code in Base.xml:
   <ButtonAction Type="Macro">
      <ID>User_Defined_Macros</ID>
      <Name>STR_USER_DEFINED_MACROS</Name>
       </ButtonAction>
No [image] tags pointing to User_Defined_Macros.png. I changed the image file name to the following:
C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg\Images\3DxService\User_Defined_Macros1.png
Now it doesn't show up in my radial menu. Unfortunately, it also doesn't show up in the GUI for other user-defined macros, but I'm ok with that.
I wonder how that happened?
Michael Hoopes
gravanoc
Post by gravanoc »
That's interesting. I'm not sure. I'm just an end-user as well, but I've been looking over all the XMLs & configs. There's a lot of functionality that can be changed. I've found literally every tag that's there, and there a lot of them.
For instance I just found out how to simulate mouse movement which is great for apps where you need to move in a straight line in some direction. I'll let you know what I figure out as I go. BTW, which mouse do you use?
mhoopes
Post by mhoopes »
I have a SpaceMouse Pro, and a Logitech G600. Yeah, it is strange to me that it reverted. Usually, that would mean that something changed somewhere in %userprofile%\AppData\Roaming\3Dconnexion\3DxWare\Cfg, though I haven't found any other occurrences of <ID>User_Defined_Macros</ID> (yet).
Michael Hoopes
Grimmy
Post by Grimmy »
Hi everyone. In the end I built my own menu to improve on what we have. You can see a video here..
https://store.steampowered.com/app/1038000/Makross/
I'm hope many of you will find it as incredibly useful as I do :)
Cheers
antonynealrobinson
Hurrah, finally got a working 8 section radial menu in Creo by removing the User_Defined_Macros.png
radial menu.png (24.29 KiB) Viewed 15869 times
Try the latest version.
