Unfortunately, now, I have this same problem with 2008, so I can't use the Space Navigator in 2D anymore.
With Autocad 2005 I was able to pan and zoom in 2D with the "Screen Mode" which work fine !
Regards
Teuf
I am using the latest driver. Release version 3.5.5, Driver version 6.5.4, Firmware version 3.11rstadie wrote:Hi mxyamaha,
Please be sure to use our latest driver. What error-message do you get?
Hello rstadierstadie wrote:Hello teuf,
when I start AutoCAD 2008, I am in "2D Wireframe". There you should be able to zoom and pan. When you open the ControlPanel in 2D mode, what configuration is enabled? What 3DxWare Version do you have installed?
Thanks rstadierstadie wrote:Hello Teuf,
Please try using F7 - that should improve the performance in 2D-Wireframe-mode, it toggles GRIDMODE on/off.
Because I often use Autocad in 2D mode, I created a 2D configuration in the control panel which disabled "tilt" and "rotate" functionsWhen you open the ControlPanel in 2D mode, what configuration is enabled?
