I have installed the spacepilot driver using the english language setting, but the driver and config panel only runs in German. I using the Swiss German language setting in the windows control panel, which is why i?m guessing the spacepilot is running in german.
My question is, how do I switch the spaceball driver / config panel to English?
Change Language Settings for Spacepilot
If you do not want to change your locale to "English", you can will need to overrides the language detection by setting a variable on the Windows Registry.
Important: a mistake when editing the Windows Registry may render your system usable. Only follow the procedure below if you are confident that you understand the instructions. Always make a backup of the Registry before editing.
Using the Registry Editor (regedit), go to HKEY_CURRENT_USER\Software\3Dconnexion\3DxWare and create new value (string) named "CurrentLocale" (without the quotes) and set it to "1033" (without the quotes). Restart the driver and the panel should now be shown always in English.
Re:
Thank you,
I had the same problem and this solution worked perfectly.
ngomes wrote:If you do not want to change your locale to "English", you can will need to overrides the language detection by setting a variable on the Windows Registry.
Re: Change Language Settings for Spacepilot
Help me Guys..
Hey guys i do as you do but it wont work, what im doing wrong ? Win 10..
And viewer and trainer in english but only properties in German !!!
Cheers
Cheers
- 1.JPG (74.8 KiB) Viewed 16023 times
Hi syhdesign,
this is an old post and the information was valid for our legacy driver 3DxSoftware. Now - with 3DxWare 10 - the information for the language is in your Global.xml file.
- Go to your AppData folder and navigate to 3Dconnexion\3DxWare\Cfg.
- Open the file Global.xml.
- Add the following:
The Cultures we currently ship are:
<Global Default="false" xmlns=""> <Settings> <Culture>de-DE</Culture> </Settings> </Global>- en-US
- de-DE
- fr-FR
- ja-JP
- zh-CN
Hi Uta,
thnx for the hint but it didn't work in my case.
I use an English Catia on a German Windows7. I installed the driver also in English Language, but the Shortcuts for Catia are German and so don't work in my English Catia.
How can I change this? Nothing works. I'd really like to use the Radial Menu.
Thanks in advance
Stefan
Thanks in advance
Stefan
this didn't work on my case.
do you know a solution for this?:
please see here
viewtopic.php?f=25&t=1581#p67031
it not work for me . I use window regoin japan.
I try to add code follow you. But it can’t change file global.xlm
