Help: New SMPro Not working with Zbrush
I am very excited -- just got a new spacemouse pro for use with Zbrush.
Do I need to download a zbrush config file or something?
Zbrush (2021.6), MacBookPro (Mojave 10.14.16)
Lots of news about Zbrush/Spacemouse integration but I don't see zbrush listed in the dropdown of supported applications. see image.
In the Properties window, I tried: Configure/Add application/ then added Zbrush, but that did did not populate buttons like "fit" with zbrush commands.
I will configure all these buttons manually if needed, but I'm wondering if I missed something during the installation. I saw a SM Enterprise video that made it very easy to configure buttons by application topics. Hoping that the SM Pro has a similar feature.
- Screen Shot 2021-04-10 at 2.03.01 PM.jpg (89.84 KiB) Viewed 12333 times
- Screen Shot 2021-04-10 at 2.13.24 PM.jpg (81.22 KiB) Viewed 12333 times
Re: Help: New SMPro Not working with Zbrush
I don't think you missed anything. We do not yet have a default configuration for ZBrush on macOS but it is likely that we will be adding one.
Client applications do not require a specific driver configuration to work well.
Thank you. I was able to remap buttons after creating some new zbrush hotkeys. I'll look forward to seeing how the zbrush integration works and what was adopted as default.
One thing haven't figured out is how to use the top buttons ( 1-4 ) while simultaneously pressing and using the stylus or mouse.
The Pop Up radial menu gets in the way and the function doesn't seem to work.
Any way to work around this? cmd-alt-drag for example.
- Screen Shot 2021-04-12 at 7.06.49 AM.jpg (33.17 KiB) Viewed 12317 times
You want to press-and-hold one of the "programmable" buttons (those labelled "1" to "4").
By default, press-and-holding any of those buttons will open the "on-screen display" panel (as shown on the screen shot above). I can't recall if there is a setting to control this behaviour and I do not have a machine quickly check. Go to the "3Dconnexion" pane in the System Preferences and see if you can find a check box to control the OSD panel.
I don't see any OSD controls. There is a "press and hold" and "press and release" Mode option for the buttons, but that doesn't seem to help.Go to the "3Dconnexion" pane in the System Preferences and see if you can find a check box to control the OSD panel.
Yeah, those top buttons would be really nice to use.
BTW I am loving the spacemouse with zbrush despite these issues. MUCH more fluid and natural sculpting compared to the stylus/keyboard navigation. wow
- Screen Shot 2021-04-12 at 10.17.06 AM.jpg (127.23 KiB) Viewed 12304 times
I just confirmed. On the Mac, we don't have a user interface to disable the opening of the OSD panel on a press-and-hold action of buttons "1" to "4". If you wish to keep a button down, you will need to use another button for the time being.
We don't know if we can make a change to address this. It hasn't been an issue until now, as far as I can recall.
Thanks for verifying this.
As you probably know Zbrush uses lots of combinations that require holding down command, shift, alt, space, while dragging or sculpting.
And just for ergonomics I would like to use two big keys for shift and alt. Those keys are used almost constantly while modeling And having larger ones would be nice and ergonomic.
I hope you can implement disabling the OSD for us Mac users.
Don’t hesitate if you have other questions to support it.
Thank you!
Thank you!
Argh.
Now the "R" and "roll-lock keys stopped" working -- I am unable to configure them.
I uninstalled the driver, reinstalled and ran the demo.
A clue perhaps, in the teapot demo, the Tilt, Roll and Twist do not work.
Another clue maybe, after the uninstall, reinstall, the last custom Zbrush config was loaded. So do I need to do more to completely uninstall?
In that same cluster of keys, the F, T and RollCW buttons configure and work just fine.
I also tried deleting the Zbrush configuration, using defaults, etc. Nothing seems to help.
Frustrating. Any ideas?
We will come to this later.
Firstly, we should check why you're seeing the following:
That's not a "demo", it's the "trainer" application. The first panels are dedicated to explaining how translations work. Rotation isn't used until later in the process. How far along the trainer steps did you go?in the teapot demo, the Tilt, Roll and Twist do not work.
Alternatively, you may have disabled rotations inadvertently. The trainer will use the config for "Any Application".
Once we have confirmed your SpaceMouse can control the trainer application in all six degrees-of-freedom, we will continue to see what's up with the buttons.
Yes, I did the full trainer, step by step. Inside the trainer, Spin, Tilt and Roll did not function in their respective tabs, nor when in the "All Active" tab.Rotation isn't used until later in the process. How far along the trainer steps did you go?
As I mentioned, when I am inside Zbrush, spin, tilt and roll continue to work.
The plot thickens.
Please confirm if rotations are enabled in the "Any Application" driver configuration (which is the default and used for the "trainer" application). For this, open the "3Dconnexion" pane in System Preferences and select "Any Application" in the "Configure" pull-down menu. Then check the tabs to see if "Rotations" are disabled.
Rotations do not work with "any applications" either.
Also with "any application" configuration, the "R" and "Button Rotations On/Off" do not work.
- Screen Shot 2021-04-15 at 7.26.11 AM.jpg (107.87 KiB) Viewed 12213 times
This is definitely unexpected.
Please confirm the exact driver version as shown on the "Tools" tab.
Below is a screenshot with the default mapping for the "Button Rotations On/Off.
It's driver version 1.1.2.184
Here's a screenshot that includes the Any Application button mapping.
PS Everything was working fine early yesterday. At some point I used Export Configuration and checked the "Export All Settings." And later imported that config file. Not sure if that coincided with the issue though. Like I mentioned, since it stopped working, I uninstalled and reinstalled the driver and the Zbrush config was listed without any action on my part.
- Screen Shot 2021-04-15 at 8.18.57 AM.jpg (172.67 KiB) Viewed 12207 times
I don't recognise that version.
You will find the full version details in the "Tools" tab of the "3Dconnexion" pane in System Preferences.
Try the following process to reset the user driver settings.Everything was working fine early yesterday. At some point I used Export Configuration and checked the "Export All Settings." And later imported that config file.
Note you will lose all your changes to the driver settings.
- Close System Preferences, if opened (this is important).
- Open Activity Monitor, select "3Dconnexion Helper" and quit the program.
- In Finder, go to menu "Go", select "Go to Folder..." and enter "/Users/<your user name>/Library/Preferences" (without the double quote characters).
- Drag the "com.3dconnexion.mapplings.plist" to Trash or any other location if you wish to back up the file (this is where the user changes are stored).
- Go to System Preferences and open the "3Dconnexion" pane (this will relaunch the driver).
- Check if the issue is still reproducible.
