problemi con esprit tng , dp tecnology
gigi
Post by gigi »
Buongiorno a tutti,
è anni che utilizzo esprit tng con il mouse space compact usb
da un giorno all altro non me lo vede piu e non funziona
ho provato a fare tutti gli aggiornamenti del caso driver e aggiornamenti windows ma niente
se lo utilizzo con creo element sullo stesso pc funziona
quindi credo sia un problema esprit
vi prego aiutatemi sono idsperato :)
grazie a tutti
aalsalihi
Re: problemi con esprit tng , dp tecnology
Post by aalsalihi »
Hi gigi,
The 3D Mouse needs to be manually activate ("Above Extras -> Addins -> 3D Mouse Activation ")
If the device is still not working then its because the integration problem Esprit have on there end. There's nothing within our software to help resolve this issue and you would need to contact Esprit support for further help.
Regards,
Abdul. A
luping
Post by luping »
Allow the 3DxWare 3Dconnexion plugin to autoload in the add-in list.
luping
Post by luping »
At the ESPRIT TNG application window, go to menu bar's File>Add-Ins, at the Add-in Manager window, go to Load Behavior section, tick "Loaded/Unloaded" and "Load on Startup", then along with 3DxWare driver installed, you should be able to use SpaceMouse Compact in ESPRIT TNG.
add-in manager.png (17.77 KiB) Viewed 3185 times
