First of all sorry for my bad english.
I've been a very satisfied user of SpaceNavigator SE for an year now. I've mostly used it with Google Earth until I started learning Photoshop.
I installed the plugin, found it really USEFUL and even found a way around brush size adjustement and different keyboard layouts. I use italian Photoshop and an english layout for evry program (I'm used to it since my first IT years). The solution has simply be to change shortcuts for brush size from ò and à to [ and ]. They have even been more easy to reach by keyboard!
All was OK up to with 3SxSoftware 3.4.2, then one day I jumped here and decided to download version 3.5.6.
I've got two big problems:
1) brush size adjustment didn't work anymore
2) (even worse) each and every time I started Photoshop I got a requester telling me that no key shortcut was associated with 3DxPhotoshop and how to do it. No matter how much time I tried (using eg f11), at every start of Photoshop I got that requester.
At the end I had to uninstall 3.5.6 and back to 3.4.2.
It should be noted that I use a customized Photoshop keyboard shortcut setting, with different keys for brush resize (as mentioned) and Undo.
Is this a bug? Is there any solution?
Thanks in advance.
