Where did the 3dconnection toolbar go to in Solidworks? Used to be able to click on any point in a part and set it to rotate about that point. Can't seem to do that anymore?
Any suggestions?
Rotate about point - Solidworks
mtrzcinski
Re: Rotate about point - Solidworks
Hey T_Warris,
Open 3Dconnexion driver => Advanced settings => Other options => Move Selected Objects.
I believe this is what you are looking for.
Mitch
Mitch
- Attachments
- Capture.JPG (78.82 KiB) Viewed 5845 times
Thanks for the response. Not quite what I am looking for. On SolidWorks there used to be a 3dconnection toolbar where you could select a point on any object and it would pivot around that point. Without it, it's quite cumbersome to move around.
Hi T_Warris,
as the toolbar was removed by design you can now find this function available in the button mapping:
- Attachments
- SetCenterPoint-Axis.jpg (175.1 KiB) Viewed 5777 times
