Inventor/AutoCAD Commands Lacking Functionality
sg000
Post by sg000 »
After 4 years I finally upgraded the driver for my Spacemouse Pro to play nice with Windows 10 and My Autodesk 2014 products for AutoCAD and Inventor. UGH! While AutoCAD is a lot more reliable (it doesn't freeze up), I can't map the buttons to anything I need to work.
I have 2 main requests. Be able to take a measurement and zoom to fit. I can't make either of them work. And all the other rotation buttons don't do their job either. What's the solution here? Can't be the only one with this problem.
--Scott
Re: Inventor/AutoCAD Commands Lacking Functionality
Hi Scott,
The navigation for Inventor is native to the application, but the Add-In is necessary for the buttons to function properly. The Add-In can be found by opening a file and selecting the Add-Ins button found on the Environments tab in the ribbon. The 3DxInventor Add-In must be loaded, and it is recommended to be loaded automatically.
Inventor Addin Loaded
sg000
Post by sg000 »
OK, now that I know what I'm looking for, I can see I didn't have it. Hope this helps someone else. I had to reinstall the same driver, then that listed in my add-ons. First load of a new command is awefully slow and had to reload the object I was working with and now it seems ok. Thank you.
sg000
Post by sg000 »
And Reinstalling the driver broke my AutoCAD installation. FATAL ERROR every time I try and run. Freakin wonderful.
