not all axis work propperly
keesgeerts
Post by keesgeerts »
Sometimes I've got the problem that not al direction function proper. When I push the knob to right/front the model does hardly move.
I checked the settings in 3d ware and nothing is checked out. No movement is locked.
I've installed version3.6.8.
I noticed the same probs in for example google earth
Does anyone know a solution.
Fred
Post by Fred »
Try rezeroing the device
close all apps
open the 3dcontrol panel
click on calibrate
You may need to increase the overal speed.
Increese it a couple notches.
Click on ok
Open a application and test it out.
Test the device with one of the 3Dx demos (Jet or Cube3D). Some applications (and demos) don't use all 6 DOF.
