cycle Button Assignment (3dsmax)
the command is there, but how do you use it? Can you create several mappings, and cycle through them with this command?
Hi Phil999,
If you do not have a SpacePilot (original mode, not the PRO), then the function does not apply.
If you have a SpacePilot, this function is normally assigned to the "Config" button. It allows you to step through ("cycle") the button assignment configurations in 3ds Max.In 3dsmax, in the Button Assignment, is a command called 'Cycle Button Assignment'. I want to know what this command is for, how to use it.
