SpacePilot and Maya 2020
joker0720
Post by joker0720 »
Hi, I've been using Space Pilot models with Maya for a little over a decade. I recently installed Maya2020, and I've noticed that my 'undo' list contains movements from the 3D mouse. This causes obvious issues, as when I'm animating, I move a control float around it and then may want to undo the key I created. Problem is, I have to undo several times, to get the 3DMouse movements out of the undo list. Then I can finally find the key creation and undo it. Is there a way to make it so that maya does not add the 3D mouse movements to the undo list?
mbonk
Re: SpacePilot and Maya 2020
Post by mbonk »
joker0720 wrote: Fri Feb 21, 2020 4:34 am ... I've noticed that my 'undo' list contains movements from the 3D mouse...
Could you post a screen shot of what they are?
Boban
Post by Boban »
me too, here are screens
mbonk
Post by mbonk »
Boban wrote: Wed Feb 26, 2020 1:13 am me too, here are screens
Thanks Boban, I've seen yours already and there will be a fix for what you are seeing in the next release. I'd really like to see those from joker720, though, I suspect his reported issue has a different cause.
